tandberg tt1200 ird mpeg2 dvb receiver
VE3HKS
Post by VE3HKS » Thu Mar 07, 2019 1:09 pm
Hello uzs and gals i have a question in how to set mz tandberg receiver so i can see my own signal on 437 mhz. I have the the dtx 1 which i have set on 437 mhz. Now i would like to look back at my own signal via this tandberg receiver. I have got the lnc with a lo from 2400. So i put that in my tandberg for lnc. Then i am lost .I should be able to tune the receiver which i have tried. Si I adjusted the sat frequency to 0.4370 which i take it should correspond with the frequency. However i keep getting no sync so no signaal. Is the signal from the dtx1 to small. or am i on the wrong track?
Please help. regards Rusty.
g8vpg
Re: tandberg tt1200 ird mpeg2 dvb receiver
Post by g8vpg » Thu Mar 07, 2019 4:58 pm
Rusty,
An easier start would be to set the DTX1 to a frequency which the Tandberg can tune to directly, for example 1249MHz in the 23cm band. The Tandberg will not go below 2ms/s according to the specification. Try this and see if it works.
I am guessing that you have one of these SUP2400 units that converts UHF up to satellite band. If so, 437 should come out at 1963MHz.
73 Shaun G8VPG.
VK5YYY
Post by VK5YYY » Fri Mar 08, 2019 1:31 pm
Hi Rusty
Tandberg TT1200 is pretty old now, circa 2000, firstly does it actually work? They had a high failure rate in VK
Test it with a sat dish or as Shaun suggested, if it's junk, use the box for you next project, get something modern
Your Tandberg will like 75dbuV, Value in dBm + 107dB = Value in dBuV (in a 50ohm world, but rough enough)
Your DTX1 is rated around -5dbm flat out, try 20db attenuator or use a couple 1/4 wave antennas across the bench
Remember there may be volts on the Tanberg output (to power the LNB) that will burn regular attenuators
You may need to turn off the power or use a blocker capacitor
From memory you'll damage that tuner with lots of signal, so go gently if you connect direct
Use a little L shaped wire poked into both f connectors around 60mm at 23cm if you don't have attenuators
Settings as per Shaun's suggestions
SET:DEMOD
LNC Freq.: 10.000
Sat. Freq: 11.963 (70cm) or 11.249 (23cm)
Symbol Rate: ?
Inner Code: ?
LNC Volt: On with SUP or Off for 23cm
LNC 22kHz: Off
Spectr inv.: Off
Good luck
Cheers Roger VK5YYY
