Receivers with valid signal output.
G0ATW
Post by G0ATW » Mon Mar 04, 2019 12:29 pm
Has anyone experience with current DVB S receivers I'm looking for ones with a valid signal (lock) and video output for our local repeaters.
Cheap and easy to obtain will help.
73s John.
G7JTT
Re: Receivers with valid signal output.
Post by G7JTT » Mon Mar 04, 2019 1:42 pm
I bought one of these (not from this seller mind) and I can confirm it has a lock light, also has the benefit of being S2 as well.
https://rover.ebay.com/rover/0/0/0?mpre ... 3059656526
All best John G7JTT
aerostar
Post by aerostar » Mon Mar 04, 2019 8:07 pm
I bought one of these to play with last year - for home use - it does work - in a fashion - sometimes does crash ( a Friday one perhaps). Would not recommend it in a repeater unless you test for extended period, but OK for shack use where you can power down/up to clear it. I have not found any update on its OS as there is no Manufacture named (on mine). Poor and low range remote control.
Post by G4EWJ » Wed Mar 06, 2019 2:15 am
I have a couple of Comag SL30/12 DVB-S receivers spare from a project that didn't take off, that can be modified to bring out a lock detect.
https://wiki.batc.org.uk/images/4/4f/SL ... detect.pdf
G0ATW
Post by G0ATW » Sat Mar 09, 2019 6:29 pm
Thanks for the info all I'll try to private message you Brian.
73s John.
