Global Invacom SNF-031 LNB - PLL?
G4GHD
Post by G4GHD » Thu Feb 28, 2019 3:26 pm
I'm using an old Global Invacom SNF-031 C120 Single Universal LNB on my 1.2M dish, I'm pretty sure it's PLL type, but can't find a spec. sheet stating so. Given that I'm not having any problems with SR1000 and over signals on Es'hail-2 but yet to receive anything below that rate, I'm beginning to wonder if that could be the cause.
moonbase
Re: Global Invacom SNF-031 LNB - PLL?
Post by moonbase » Thu Feb 28, 2019 3:43 pm
It is definitely a DRO LNB and not a PLL
G4GHD
Post by G4GHD » Fri Mar 01, 2019 1:47 pm
Many thanks.
Any recommendations on a C120 flange PLL LNB?
Post by g0mjw » Fri Mar 01, 2019 4:30 pm
I do not know of any C125 PLL LNBs. I have a C120 channel master horn on my 1.2m dish.
I used an octagon and a surplus c120 horn. I cut the horn off the octagon and the flange off the old horn. Joined the LNB and Flange.
G4GHD
Post by G4GHD » Fri Mar 01, 2019 8:50 pm
Ah, I was hoping there'd be a PLL version, not sure my metalwork skills are up to your solution.
Post by g0mjw » Sat Mar 02, 2019 7:45 am
Metalwork skills? A hacksaw, areldite and a hose clamp for a bit of mechanical reinforcement?
G4GHD
Post by G4GHD » Sat Mar 02, 2019 6:01 pm
I didn't realise you'd simply glued them together, doesn't sound too difficult then...
