Streaming directly from MiniTiouner
Post by g8gtz » Mon Feb 18, 2019 12:02 pm
A new page on the BATC wiki tells you how to directly stream any received signal straight from MiniTioune to your channel on BATC streamer.
This will be appreciated by those not able to receive the Oscar 100 DATV signals!
Note it does require some understanding of command line and batch files etc and it also requires a reasonable PC to receive and stream high bit rate signals at the same time.
https://wiki.batc.org.uk/Streaming_dire ... e_software
