70cm SAW filter
G4GHD
70cm SAW filter
Post by G4GHD » Tue Feb 05, 2019 10:29 pm
Has anyone used this (or similar) on receive in conjunction with a MiniTiouner?
https://www.ebay.co.uk/itm/70cm-430-440 ... 4003655576
I'm thinking this is, although better than nothing, probably a tad too wide, as I live in a pretty RF congested area.
F6DZP
Re: 70cm SAW filter
Post by F6DZP » Wed Feb 06, 2019 8:11 am
I use this filter for transmission mode after a LimeSDRMini or a Pluto, but not with a MiniTiouner. Its bandwidth is acceptable to filter 437MHz harmonics but not disturbing signals around 437 MHz.
spectre filtre saw 425MHz-446MHz.jpg (78.78 KiB) Viewed 8016 times
Jean-Pierre F6DZP
Re: 70cm SAW filter
Post by g0mjw » Wed Feb 06, 2019 8:25 am
Hi Jean-Pierre
How does the group delay vary across the bandwidth?
F6DZP
Re: 70cm SAW filter
Post by F6DZP » Wed Feb 06, 2019 9:35 am
Interesting question but I have not look at the group delay for this chip, just use it only for low SR and low level. I have not observed any difference with the signal other than 2dB loss, so go further without studying the group delay.
This is a TA1408A
You can find the datasheet here:
https://www.golledge.com/media/2551/mp04694.pdf
You can buy this chip by 5 units on AliExpress website
https://www.aliexpress.com/item/Origina ... 44173.html
Jean-Pierre F6DZP
G4FRE
Re: 70cm SAW filter
Post by G4FRE » Wed Feb 06, 2019 10:34 am
I Use
https://www.ebay.co.uk/itm/450-Mhz-Heli ... ctupt=true
in front of my minituner when not using the mhp which has onboard helicals. Tunes 430-440Mhz without issue
G4FRE
Re: 70cm SAW filter
Post by g0mjw » Wed Feb 06, 2019 11:20 am
I have something similar in a Habamp, an LNA designed for high altitude balloon reception - which I use for DATV on 70cms.
See https://store.uputronics.com/index.php? ... duct_id=53
for a more recent implementation.
G4GHD
Re: 70cm SAW filter
Post by G4GHD » Wed Feb 13, 2019 1:19 pm
Thanks for the comments and suggestions :)
ea3ta
Re: 70cm SAW filter
Post by ea3ta » Sat Feb 16, 2019 11:47 am
Some in EA3 we are using with minitiouner and with good results this:
https://www.tindie.com/products/gpio/43 ... bandwidth/
73, Juan EA3TA
PE5PVB
Re: 70cm SAW filter
Post by PE5PVB » Tue Feb 19, 2019 10:21 am
I've used this one in the past in several 70cm projects: https://nl.mouser.com/ProductDetail/ABR ... jkZw%3d%3d
