Portsdown Tx
Russell
Portsdown Tx
Post by Russell » Wed Jan 09, 2019 5:04 am
Hi I gather the portsdown Tx is DVB-S has anyone using DVB-T I'm in VK and as far as I can tell it is a legal format here is there a reason DVB-S is used in the UK forgive me for my ignorance of all this.
Re: Portsdown Tx
Post by G8GKQ » Wed Jan 09, 2019 10:28 am
Hi Russell
We do not have sufficient allocated spectrum (>6 MHz for broadcast standard DVB-T) in the UHF band in the UK to use DVB-T. Using lower bandwidth variants of DVB-S and DVB-S2 provides us with the flexibility to reduce spectrum usage and increase link budget margin.
DVB-T is too complex a waveform to be produced by the Raspberry Pi on its own; it could control an FPGA to generate the signal, but that is another level of complication and expense.
Russell
Re: Portsdown Tx
Post by Russell » Thu Jan 10, 2019 3:03 am
Thanks Dave I asked because the club here has a person that wants to get a DVB-T repeater going and we are not sure in which direction to head.
My initial thoughts were that the public could tune a normal TV to watch but now I see domestic TV only go down to ch 27 which isn't low enough foe 70cm so there isn't any advantage in going DVB-T we might have a rethink about the project and go DVB-S
Thanks again.
Russ VK4DCM
Re: Portsdown Tx
Post by g0mjw » Thu Jan 10, 2019 8:06 am
The DATV Express can produce DVB-T, however those are no longer being made. If your club are absolutely fixated on DVB-T rather than DVB-S or DVB-S2 their options are very limited, but there are commercial offerings - e.g. the HIDES UT-100 USB DVB-T Modulator, which is not too expensive. It appears to do 2K which probably would fit in our 70cm band.
G4GUO
Re: Portsdown Tx
Post by G4GUO » Thu Jan 10, 2019 9:37 am
DATV-Express software can also do DVB-T with a Lime Mini but at low symbol rates it does not really have enough filtering.
Also the output is very very low (adequate for across the shack testing though).
You can also do it with GNURadio (even DVB-T2) but don't ask me how to do it with a live camera source :lol:
- Charles
G4GUO
Re: Portsdown Tx
Post by G4GUO » Fri Jan 11, 2019 10:43 am
Here is 8 MHz DVB-T using a LimeMini, the receive antenna was a hex spanner and the Lime is top right in a Hammond Enclosure.
- Charles
