6/4m Christmas tests (1)
G4FRE
Post by G4FRE » Sun Dec 30, 2018 1:54 pm
While visiting relatives in Kent over Christmas I took along the 51 and 71MHz receive systems
I had a 5 ele 50MHz yagi and a 5 ele on 71MHz and 437/51 MHz +437/71MHz xverters into the minitune receiver
The remote controlled transmitter was left in Malvern, IO82UC was the adalm pluto with lots of post amps into a 3+3 ele yagi
On boxing day morning, 6m conditions looked promising when i received the GB3RMK @619km and GB3NGI @761 km beacons on narrowband. Pictures were successfully received from Malvern over the 228km path to JO01JK with a 13dB MER on 6m. Although the carrier was detected on 4m, there just was not enough signal for pictures
G4FRE
g4hiz
Re: 6/4m Christmas tests (1)
Post by g4hiz » Tue Jan 01, 2019 10:04 am
The reception tests look pretty good considering the location. I often do tests from JO01KJ (Warden Bay) mainly looking North/North-East on 10GHz. I guess that for your reception tests you were looking West/N-West, where were you located to get the required direction ?
73 Jen
F6DZP
Post by F6DZP » Mon Jan 07, 2019 11:25 am
I am QRV on 51MHz using Minitioune and converter.
I also use a lime mini for TX but have only 5W of power out.
I have only done some test with Evariste F5OEO that lives 5 miles from my home. Results were very good, I receided and decode his signal coming out the lime mini without anay amplifier and only a vertical antenna.
I actively search for foreign contact.
Perhaps we could do some test when the 6m band is open.
My QRA locator : JN06dp
Jean-Pierre F6DZP
