TECHNISAT SKYSTAR 2 PCI DVB-S card
SV8QG
Post by SV8QG » Tue Dec 04, 2018 4:01 pm
I have in use a TECHNISAT SKYSTAR 2 PCI DVB-S card, can be used for Es’hail-2 reception?
73s Alex
G4GHD
Re: TECHNISAT SKYSTAR 2 PCI DVB-S card
Post by G4GHD » Wed Dec 12, 2018 4:29 pm
Its symbol rate range will probably be inadequate, although you could always give it a try. Most TBS cards are more suited for the lower rates required.
SV8QG
Post by SV8QG » Fri Dec 14, 2018 11:38 am
G4GHD Thank you for your suggestions, it seams to me it’s time for a new card. Have I any benefits from a USB interfase instead the a PCI card?
73s Alex
G4GHD
Post by G4GHD » Sat Dec 15, 2018 3:08 pm
Personally I'd opt for a PCI-e card rather than USB, but if you have USB 3.0 ports, the speed should be good enough.
