146-147 NoV Renewal for 2018/9
Discussion and announcements about ATV related spectrum
g6jyb
Post by g6jyb » Fri Sep 28, 2018 3:12 pm
From GB2RS:-
All current 146-147MHz band Notices of Variation (NoV) expire on Tuesday the 31st of October. Ofcom has agreed that the band will be made available for another year. However, to continue to use the frequencies you must obtain a new NoV. These are available free from the RSGB website via www.rsgb.org/nov
regards
Murray G6JYB
Re: 146-147 NoV Renewal for 2018/9
Post by g0mjw » Fri Sep 28, 2018 3:58 pm
Thanks Murray,
I also refreshed my 71MHz NOV as my original was due to expire in a couple of weeks.
Again, 100W ERP. My antenna has (allegedly) 9 dBd gain allowing me to run 12.5W. That's just a bit more than my RA30H0608M module can manage with good shoulders so no problems there. The closest I have been to Scotland of late is the yard, so no problems there either.
These two are a bit more challenging.
(c) The use of the Station in the Authorised Band must not breach the agreed international coordination limits applicable to the Authorised Band.
(d) If the Licensee can demonstrate that the use of the Station in the Authorised Band complies with relevant provisions of the Harmonised Calculation Method agreement, it may be taken to show that the use of the Station in the Authorised Band is not breaching the agreed international coordination limits applicable to the Authorised Band.
Post by G3GJA » Mon Oct 01, 2018 11:30 pm
Just successfully applied for the 71MHz NoV but two attempts to renew the 146/147MHz NoV has failed. Has anyone else had trouble with the NoV application process?
Clive G3GJA
M5TXJ
Post by M5TXJ » Tue Oct 02, 2018 7:18 am
Hi Clive,
Just renewed my 146.5MHz NOV with no problem here.
73 Dave.
Post by G3GJA » Tue Oct 02, 2018 11:45 am
Tried again this morning and it worked with the same browser and PC combination so it looks like it was just a temporary glitch...
Clive
Return to “Spectrum matters”
