Express_DVB_Transmitter software install
wb6kwt
Post by wb6kwt » Sun Jul 15, 2018 8:05 pm
I'm trying to install the newest version of the windows software. I had an older version running on my old laptop but can't get it installed on this laptop. I'm getting "MSVCR120.DLL NOT INSTALLED" I remember having this issue before but for the life of me I'm not able to figure out how to get it installed. Google hasn't helped. I thought I might be able to copy the DLL from my old system and paste it into the Express directory but no luck. Your suggestions please.
Thanks,
Bob wb6kwt
Re: Express_DVB_Transmitter software install
Post by G4GUO » Sun Jul 15, 2018 8:25 pm
Have you looked in the notes file that comes with the distribution?
= Charles
wb6kwt
Post by wb6kwt » Sun Jul 15, 2018 9:40 pm
yes, guess I missed it, if it's there, I'll have another read.
Bob
M0SKM
Post by M0SKM » Sun Jul 15, 2018 9:42 pm
Hi Charles,
I have the same error message after installing the suggested software.
(3) You will also probably have to install the VC++ 2015 re-distributable (32 bit version)
Two files are not found MSVCP140.dll and VCRUNTIME140.dll
Checked the system32 folder and both are present.
Steve
Post by G4GUO » Mon Jul 16, 2018 8:22 am
Hi Steve,
I Googled the problem and it seems that it is because the re-distributable is not installed.
All I can suggest is that you re-run the Microsoft installation program as I suspect some
symbolic links have not been setup. It must be the 32 bit version not the 64 bit version.
M0SKM
Post by M0SKM » Mon Jul 16, 2018 11:22 am
Running the re-distributable in repair mode has solved the problem. Given that Windows 10 and the Visual C++ files were a fresh install on Sunday I'm a bit surprised.
So I've given your new beta software a quick preview with Pluto; results using DVB-S2 are very impressive.
Thanks for your time and effort on a very useful software package.
Steve
wb6kwt
Post by wb6kwt » Mon Jul 16, 2018 12:44 pm
Thanks Steve, I'll give the repair option a try because the DLL file is installed on my laptop and I still get the error.
Bob wb6kwt
G8XZD-TV
Post by G8XZD-TV » Sun Nov 18, 2018 9:50 pm
At the risk of resurrecting an old thread...
I've just had to reinstall win10 on my tablet which drives datv express.
I have rtfm and still get the missing mscv120 dll message when trying to run the software.
A previous version of the software 1.23 doesn't give the same problem.
Have tried repairing and reinstalling the 32 bit version of 2015VC++ with exactly the same results.
Any suggestions?
73. Ian.
PS not been a good week getting back on air :-(
g0uhy
Post by g0uhy » Sun Nov 18, 2018 11:12 pm
Hi Ian,
I had a similar problem when a Windows update went wrong and had to reinstall Windows 7.
The problem was the redistributables but I ended up having to install previous versions before the 2015 one. I also installed the 64bit and 32bit files. I'm not sure which one actually solved the problem but it worked for me...hi.
Malcolm G0UHY
G8XZD-TV
Post by G8XZD-TV » Wed Nov 21, 2018 5:27 pm
In the end it was the 32 bit version of vc++ distributable 2013 that made it work for me on a fresh windows install.
Hope this helps anyone elser in the same poition. Ian.
