Final Call for Contest Entries!
Post by G8GKQ » Sat Jun 23, 2018 8:03 pm
Entries for the IARU International Contest and the BATC 146 Contest need to be submitted by Monday 25 June to be valid. I have not yet received logs from:
GI0GDP
G8VDP
2E1ACS
G0RPH
G6ZVE
G4FVP
G6AUR
G3ZGZ
G1ZIM
G0VQH
G3KJX
It doesn't matter if you only had one contact - please tell us about it. If you can't get the Excel spreadsheet to work, just send me details in an e-mail - I'll sort it out. By the way, it is very unlikely that you will come last, as some courageous souls have submitted entries with very low scores already!
Completed logs should be submitted to contests@batc.tv I will acknowledge receipt of all logs.
The spreadsheet for 432 MHz and up is here: https://www.iaru-r1.org/images/VHF/atv/ ... YYMMDD.xls
The spreadsheet for 146 MHz is here: https://wiki.batc.org.uk/images/2/28/14 ... YYMMDD.xls
Some notes on the Scoring spreadsheets:
  • You must "Enable Macros" on opening the spreadsheet to all all the calculations to run.
  • To be valid for points, a the report must be at least P2. By definition, a P1 picture is not good enough to read numbers.
  • If you are not comfortable with using Excel, please simply submit your log as an e-mail or word document.
