IARU Region 1 Contest 9/10 June
M0YDH
Re: IARU Region 1 Contest 9/10 June
Post by M0YDH » Fri May 18, 2018 9:34 pm
Martyn G3UKV and I plus friends are planning to be on the summit car park of Brown Clee Hill, Shropshire [52.4755446N, 2.59903675W] on Sunday 10 June. Martyn has permission to use the access road. I've only ever activated G/WB-002 for SOTA so this is different.
I'm working hard on the DATV system for 70cm and 23cm but the list of still to build / test is long. :roll:
Cheers
David M0YDH
Post by g8gtz » Sun May 20, 2018 7:11 am
We've created a wiki page giving more background to the IARU contest including a link to last years results - https://wiki.batc.org.uk/IARU_ATV_contest
Please continue to post your plans on here.
Post by g8gtz » Mon May 21, 2018 8:54 am
My current plan is to go to Whether Down near Petersfield (IO90LX) on the Saturday to work locals in the south of England plus maybe F9ZG and other French stations.
Bands will possibly include:
144.75 MHz NBFM talkback
146.5 MHz DATV
437 MHz DATV
1255 MHz DATV
13cms DATV
9cms DATV
5665 MHz FM ATV
10GHz DATV
24GHz DATV
76GHz DATV
On Sunday, current plan (but not confirmed) is to go to Penn Mill (IO81QF) on the Mendips, primarily to work stations in Bristol and the South West / Wales but also hope to work the team on Brown Clee.
Please post details of your planned activity here and monitor 144.75 MHz and https://www.dxspot.tv/ during the contest.
More updates nearer the time...
M5TXJ
Post by M5TXJ » Mon May 21, 2018 1:53 pm
The postman has brought the next step to being QRV.
M5TXJ
Post by M5TXJ » Thu May 24, 2018 1:53 pm
Trial fit in the van, other than psu is there anything I've obviously missed?
73 Dave.
Post by M0DTS » Mon May 28, 2018 4:54 pm
I will be at IO94MJ on the Saturday, paths to North and South possible.
Not sure about Sunday yet, depends on activity.
Will be active on all bands 146-24GHz ATV/DATV
Hope to see some new faces ;-)
M0DHP
Post by M0DHP » Wed May 30, 2018 3:53 pm
I'm only free on Sunday 10th. My plan for the first outing with my Portsdown is to work 437MHz DATV from Whitesheet Hill (IO81UC).
Dave G8GKQ, I should have a good line-of-sight to you on Bullbarrow Hill.
M0SKM
Post by M0SKM » Wed May 30, 2018 4:05 pm
M0SKM wrote:
Tue May 15, 2018 3:18 pm
On the Sunday I'll be on Dunstable Downs running.
146.5 MHz DATV
437MHz DATV
2405 MHz DATV
5665 MHz ATV
Now on Dunstable Downs Saturday 9th with G4CPE; 5GHz Sked with Ian G3KKD.
Talkback 144.750.
Find me on D Star through GB7BP
Post by G4EWJ » Mon Jun 04, 2018 6:39 pm
G3NWR / M0SII will be mounting a joint Wirral ARS / Salford University RS roving expedition. The plan (if we don't run out of energy) is to start at Kirkstone Pass IO84ML at 1300 local on the Saturday, then move to Jubilee Tower IO84PA and then move to Winter Hill IO83RO. It would be hard to pin down exact times.
It's possible that on Sunday we may go to Esclusham Mountain IO83KB. That's northerly facing, but if the group on Brown Clee have a northerly take-off, we could stop at a lower southerly facing site on the way.
We'll have 2m D, 23cm A/D, 13cm A/D, 9cm D, 6cm A, 3cm A/D.
M5TXJ
Post by M5TXJ » Mon Jun 04, 2018 7:11 pm
Hi Brian, I should be QRV from Gt Dun Fell at approx 1200 so please point your 2m beam my direction.
73 Dave.
