MiniT with UDP to VLC
g3zgz
Post by g3zgz » Sat Feb 17, 2018 9:30 am
I read that VLC can be used to display a UDP stream from MiniT
I see in the MiniT INI file there is reference to UDP address and local IP address.
Could you please point me in the right direction as to what I need to set these IP addresses and how to use VLC to pick up this stream?
G3ZGZ
F6DZP
Re: MiniT with UDP to VLC
Post by F6DZP » Sat Feb 17, 2018 11:02 am
in the minitioune .ini file you can find :
; adresse UDP / UDP address
[UDP]
AddrUDP=230.0.0.1
;AddrUDP=127.0.0.1
Port=1234
If your computer is linked to a Network ( Wifi or Ethernet, local network or Internet Network) you have a Net card that is presently working, so you can let the IP value 230.0.0.1
If your computer has no network running, you must use the virtual IP address : 127.0.0.1
You satr Minitioune. When you are receiving a Transport Sream (TS), you switch on the UDP button.
=> the TS is sent to the UDP address:port written in the .ini file.
Start VLC, click : Media ==> Open Network Stream
under "Enter a network URL" you write:
udp://@230.0.0.1:1234
or
udp://@127.0.0.1:1234 ( if you have written this in the .ini file)
you click play.
You will see the video decoded by VLC.
Jean-Pierre F6DZP
g3zgz
Post by g3zgz » Sun Feb 18, 2018 7:36 am
Thank you JP for your very quick reply.
This was exactly what I needed to get it working nicely.
You have put a lot of time and effort into the software and it's really appreciated by the many stations that use it.
G3ZGZ
