TX button on screen display
F1SSF
Post by F1SSF » Sun Feb 11, 2018 4:37 pm
Hi alls,
Very often, when I press TX button to stop tranmission, TX stop, and restart immediatly.
Impossible to stop TX, I must going in generator menu , and TX stop.
What do you think about this ?
Best 73 Franck F1SSF
Re: TX button on screen display
Post by G8GKQ » Sun Feb 11, 2018 8:40 pm
Franck
What screen are you using? Do you use a pointing stick or your finger? What vision source is this with? Camera, or testcard or what?
F1SSF
Post by F1SSF » Sun Feb 11, 2018 9:04 pm
Thk's , I use the last update version, no stick, my finger only .
For my source, I use TS file on USB key.
My screen is correctly calibrate, problem only with TX touch.
When I press TX to STOP, the PTT led turn OFF, but when I released my figer on TX button, PTT return to ON, and RX button is again red.
it's unpleasant hi....if you have an idea.
All the best, 73
Franck
Post by G8GKQ » Tue Feb 13, 2018 9:11 am
Franck
Is the problem only in FileTS mode, or does it happen in other modes as well?
F1SSF
Post by F1SSF » Tue Feb 13, 2018 11:53 am
Dave,
I 've found an intermediary solution, I press others buttons, and TX stop..
Not important at this time......it's more more easy now, it is peharps a good method :)
I continue my portsdown tests.
Many thank's
Franck
Post by G8GKQ » Tue Feb 13, 2018 4:46 pm
Hi Franck
I’ve found the bug. It will be corrected in the next update - hopefully later this week.
F1SSF
Post by F1SSF » Tue Feb 13, 2018 6:15 pm
Super Dave, not urgent. Tk's
73's
Post by G8GKQ » Wed Feb 14, 2018 12:29 pm
I've just released the software update that includes the fix. Thanks for reporting the bug - I can only fix problems that I know about!
