146.5MHz South Wales to Taunton Tests
GW0KAX
Post by GW0KAX » Sun Feb 04, 2018 9:34 pm
During the January ATV Activity weekend, I had attempted to work Noel and the Bristol Guys, on 146.5MHz, without Success, mainly as the path to the East here is restricted.
Last Thursday, Adrian G4UVZ suggested running some tests on 146.5MHz, Taunton is Approx due SSE of my QTH so the path is better.
After some issues were sorted, we successfully exchanged pictures on 2m, path length was about 46 Miles :D
Some photos of the exchange:
Petrie
GW0KAX
GW0KAX
Re: 146.5MHz South Wales to Taunton Tests
Post by GW0KAX » Sun Feb 04, 2018 9:41 pm
And another.....
G4uvz
Post by G4uvz » Fri Feb 09, 2018 9:35 pm
Great contact over quite an obstructed path ..learning point ...line up antennas on fone before trying NBDATV!
...Anyone in Wiltshire ready for 2M tests?
Adrian
M5TXJ
Post by M5TXJ » Fri Feb 09, 2018 10:22 pm
What power was being used?
73 Dave
GW0KAX
Post by GW0KAX » Thu Mar 01, 2018 8:09 pm
Hello Dave,
My end, DATV Express with G4DDK Amplifier, about 4.5W into a 12ele PowAbeam at 50 feet.
Amplifier: https://www.dg0ve.de/en/index_htm_files ... 017_01.pdf
Petrie
GW0KAX
Post by g0mjw » Fri Mar 02, 2018 8:03 am
Hello Dave,
Amplifier: http://www.g4ddk.com/144MHz8WPA.pdf
Petrie
GW0KAX
What is the gain of the powerbeam? Is it this one https://www.thedxshop.com/powabeam-ante ... 2n50x.html Quite a monstor on an 8m boom.
I am really surprised that PA can give 4.5W on DATV. Normally you are lucky to get 10% of the maximum CW output.
GW0KAX
Post by GW0KAX » Sat Mar 03, 2018 10:52 pm
Hello Mike,
Edit: I've got the CQM12UX, 6m long, I've assumed 12dB Gain for ERP calculation.
Got the Amps Mixed up!, I use this one at home https://www.dg0ve.de/en/index_htm_files ... 017_01.pdf & the other one I use in Cardiff.
Also use a 30ele PowAbeam Antenna on 70cm with a https://www.dg0ve.de/en/index_htm_files ... 017_01.pdf Amp.
So if anyone in the South Wales / South West wants to do a test on 2m or 70cm, give me a shout!
Petrie
GWOKAX
Post by g0mjw » Sun Mar 04, 2018 7:44 am
I don't think I would get away with one of those antennas here. I have a 17 element Tonna and its a bit too large. The DG0VE is a nice implementation of the high power RA module. Unfortunately these modules seem to be going out of production.
