vMix 2Portsdown.bat error
F1SSF
Post by F1SSF » Sat Jan 06, 2018 5:22 pm
Hi alls,
I have an error with the bat file after configuring it like the wiki.
Input #0, dshow, from 'video=vMix Video':
Duration: N/A, start: 88481.377000, bitrate: N/A
Stream #0:0: Video: rawvideo (UYVY / 0x59565955), uyvy422, 768x576, 25 fps, 25 tbr, 10000k tbn, 10000k tbc
[dshow @ 06f74ac0] real-time buffer [vMix Video] [video input] too full or near too full (87% of size: 3041280 [rtbufsize parameter])! frame dropped!
can you help me please?
Regards, and happy new year.
Franck F1SSF
Re: vMix 2Portsdown.bat error
Post by g0mjw » Sun Jan 07, 2018 8:35 am
I didn't realise the Portsdown could do 10Ms. I doubt the PI Ethernet could keep up.
Maybe I need to explain in more detail. It may not be related unless you are attempting to use a UDP transport stream. The PI ethernet shares with the USB2 bus. This is a bottleneck and you probably won't get the full 100Mbit/s bandwidth, especially if there is anything else using the USB. A symbol rate of 10M symbols per second is 80Mb/s is getting towards the limit and then there are the overheads. A simple test is to reduce the rate and see if it works.
F1SSF
Post by F1SSF » Sun Jan 07, 2018 2:01 pm
hello,
At this time, I have use this wiki:
.https://wiki.batc.org.uk/Feeding_Video ... _from_vMix
So when I execute vMixportsdows.bat, I can set the SR, FEC....
The most little SR is 1000, I don't know more reduce the rate in the script.
Best 73
M0DHP
Post by M0DHP » Sun Jan 07, 2018 8:48 pm
Hello Franck
In my tests of vMix to Portsdown, I sometimes get frame dropped errors but without noticeable effect on the picture quality. How often does that error message appear? is it just occasional or is it a constant stream of error messages?
If you look further down the wiki page, there is a new "beta" version of the file that adds 333kS/s.
Ray
F1SSF
Post by F1SSF » Mon Jan 08, 2018 6:16 am
Hi Ray,
.is it just occasional or is it a constant stream of error messages?
It is a constant error à 95% , sometime I can see yellow correct lignes.
Ok for beta, I could test it this week.
See you later, tnx
73 Franck F1SSF
M0DHP
Post by M0DHP » Mon Jan 08, 2018 8:58 am
When you get the errors, do you have the PC (that runs vMix and the batch file) connected via network to the Portsdown? Is the Portsdown configured for IPTS source and set to transmit after you run the batch file?
And do you receive pictures from the Portsdown?
F1SSF
Post by F1SSF » Mon Jan 08, 2018 9:46 pm
I have tested the file version with 333kc/s, same problem.
Yes the network is the same, Vmix is running and configured, RPI is setup in IPTS ,and Txing.
@73
F1SSF
Post by F1SSF » Mon Apr 02, 2018 7:26 pm
Hi alls,
After a long time, I have decided to change my computer , and I have installed again software.
It's OK now, Vmix, and VmixPortsdown.bat running very well.
Also I have some mistakes PASTE DURATION TOO LARGE during batch run.
See attached pictures, what do you think about it?
Best 73 Franck
Post by G8GKQ » Mon Apr 02, 2018 9:56 pm
Hi Franck
Are the transmitted pictures OK? If so, do not worry. ffmpeg complains a lot, but does the work.
If you do not have a good transmission, then we need some information about what SR and FEC you are using.
F1SSF
Post by F1SSF » Tue Apr 03, 2018 5:02 am
I transmit vidéo, and pictures across Vmix, and it's perfect.
.ffmpeg complains a lot
Thank you for this capital information :P
73 Franck F1SSF
