Digi-Key + BOM spread sheet upload
G1BVI
Post by G1BVI » Mon Nov 20, 2017 11:08 am
Hi all
Just sorting out my order to Digi key and realised that you can upload the BOM directly to the web site.
I am sure most probably realise this but it makes ordering so much easier.
When you upload to your basket you get images of each component you are purchasing.
Make sure you remove the USB Module if you have ordered this from the BATC shop.
The jumper seems to be missing from the BOM which links the supply so next job is to locate the Digi key part number for this and advise G8GTZ.
I am lucky that a work colleague is also placing a large order with Digi key so I am avoiding the crazy p and p costs.
A heads up for those who have not yet ordered parts is that there is a long lead time on the ferrite beads (22/1/2018)
Nick
Re: Digi-Key + BOM spread sheet upload
Post by G4GUO » Mon Nov 20, 2017 11:25 am
Digikey.co.uk shipping is free to the UK for orders over £33
G1BVI
Post by G1BVI » Mon Nov 20, 2017 12:01 pm
The jumper/shunt for the harwin headers looks like it should be this
https://www.digikey.co.uk/product-detai ... ND/3922868
Digikey # 952-2573-ND
This I believe should be added to the BOM
Hope this helps other builders
Nick
MN-tech
Post by MN-tech » Mon Nov 20, 2017 12:15 pm
You can have your component numbers printed on the packets if you add them to a column in your spreadsheet. When you place your order upload them to the customer reference field in addition to Digi-Key number and quantity.
Post by radiogareth » Tue Nov 21, 2017 12:29 pm
Farnell have the ferrite chokes. I bought the box and some other bits from them to hit MOQ and free delivery.
