Help with PuTTY please
G1BVI
Post by G1BVI » Fri Nov 17, 2017 8:33 pm
Hi all
Hope aomeone can advise where I am going wrong.
I dowloaded Jessie and put it on to an 8GB card.
added ssh in the root as per instructions.
running the advanced IP scanner I could not see the Pi so I interrogated my router and found the IP address.
putting the ip address into PuTTY and changing no settings PuTTY returns a fatal error 'network error software caused connection abort'
What have I missed?
Thanks in advance
Nick
Re: Help with PuTTY please
Post by G8GKQ » Fri Nov 17, 2017 8:59 pm
Hi Nick
To help us diagnose the problem, please can you post:
- What is the configuration of your network? Is the PC wired directly to the router? Is the Pi wired directly to the router?
- What IP address did your router say the RPi had? What is the IP address of your PC?
- What happens if you type "ping 192.***.***.***" (where 192.***.***.*** is the IP address of your Pi) at the Command Prompt on your PC?
- Please re-check that the filename of the ssh file is really ssh, and not ssh.txt (which Windows will display as ssh).
Sorry it's so many questions.....
G1BVI
Post by G1BVI » Fri Nov 17, 2017 9:10 pm
Hi Dave
The pi is connected to the router and the router gives rpi address as 192.168.1.138
The PC is on the wifi and is 192.168.1.156
Tried pinging 138 and there is no response.
Running windows 7 and I checked SSH in notepad on one of attempt saved it as all files ensuring it has no extension too.
What I have also noticed is that after it fails , I read the card on a PC again and the SSH file has gone??
Nick
G1BVI
Post by G1BVI » Fri Nov 17, 2017 9:14 pm
Correction Dave pinging pi produces a reply
bytes 32 time 2ms ttl 64
N
Post by g0mjw » Fri Nov 17, 2017 9:53 pm
There is a long thread on this error here. https://www.raspberrypi.org/forums/view ... hp?t=16380
Are you running any software on your PC that might block putty. E.g. some virus/firewall/security package?
Post by G8GKQ » Fri Nov 17, 2017 9:54 pm
Now that you can ping the RPi, please try Putty again, but this time turn off any Windows firewall (or any other anti-virus firewall on your PC).
The fact that the ssh file disappears is a good sign. It means that your RPi should be listening for the ssh connection.
G1BVI
Post by G1BVI » Fri Nov 17, 2017 10:26 pm
Hi Dave
I know Putty works as I have used it to talk to a linux sat box using telnet
Just reconfirmed and it works.
AV and firewall now off.
Tried to SSH to Rpi with same result.... failure
still do not understand why advanced ip scanner does not recognise it too?
N
G1BVI
Post by G1BVI » Fri Nov 17, 2017 10:45 pm
Will start again from scratch tommorrow.
Just read through most of the link you sent that did not really help.
I will also try a different router tomorrow
thanks for help
N
G1BVI
Post by G1BVI » Sun Nov 19, 2017 3:03 pm
Hi Dave started from scratch.
Reloaded SD card with the image etc.
The Advanced IP search tool now sees the Pi that it would not before?
Putty logs in properly.....................
Everything is now working...........
My conclusion something must have gone wrong with the first card install of Jessie !!
thanks again for your help
nick
Post by G8GKQ » Sun Nov 19, 2017 5:12 pm
Hi Nick
Thanks for letting us know. Great to hear success stories!
