GB3UD STREAM
sean2e0saf
GB3UD STREAM
Post by sean2e0saf » Sun Sep 17, 2017 3:06 pm
i need someone to stream gb3ud in 720/576 hd
the stream must be 24/7 it will require a minimum of a i3 cpu
unless you have good filters transmitting from your qth will not be possible as it will obviously desense your sat rx..!
a radio club would be best as a club project
please email me sean2e0saf@virginmedia.com for details
i can give you a sat rx and possibly a antenna you will need coax ecoflex is best..! and you may need a preamp
thanks all
23cms AATV from io83qn ( wn68ns )
23cms DATV from i083qn ( wn68ns )
70cms DATV from io83qn ( wn68ns )
wimo shf-2344
parabeam 70cms/18ele
Re: GB3UD STREAM
Post by G8GKQ » Mon Sep 18, 2017 9:38 am
Hi Sean
The Portsdown software on a Raspberry Pi 3 with an EasyCap will stream to batc.tv at 720x576. It would use significantly less power than an i3 and fit in half a 1U rack tray. Details here: https://wiki.batc.tv/Streaming_to_batc. ... spberry_Pi
Incidentally 720x576 isn't usually regarded as HD.
sean2e0saf
Re: GB3UD STREAM
Post by sean2e0saf » Mon Sep 18, 2017 10:49 pm
Hi dave
Thanks for the info...
Yes 720p isnt really high quality hd...
I dont know what has happened to keith g0sph stream is down and no replys via emails...
Hope hes ok..
wimo shf-2344
Return to “Streaming”
