ADALM-PLUTO (new DATV SDR)
Post by G4GUO » Fri Aug 18, 2017 8:04 am
This is just a heads up.
As those who follow me on Twitter know there is a new SDR transceiver available from Analog Devices
called the ADALM-PLUTO. It is aimed at the educational market (i.e us).
Nominally it works from 328 MHz to 3800 MHz however the current model can be modified in
software to operate from 48 MHz - 6 GHz on transmit and 70 MHz to 6 GHz on receive.
It produces about 1 mW output.
I am in the process of adding support for this device to the Express Software.
Initial tests are looking good, more work to do though.
The introductory price of the board is $99 which equates to around £91 after VAT is paid.
They are available from https://www.digikey.co.uk/products/en?k ... lm%20pluto
I just thought members might like to know about this device as it is selling fast and
at the introductory price is very cheap for something of this class.
i2NDT
Post by i2NDT » Fri Aug 18, 2017 9:33 am
i2NDT Claudio
Dalmine, Italia
Post by g0mjw » Fri Aug 18, 2017 2:49 pm
Its a very good price indeed. Mine, which arrived unexpectedly on Saturday as I had forgotten I ordered it back in April, also covers the extended range. I am not sure if that is accidental or will apply long term. At £92 and covering practically all of our DATV bands below 10GHz on transmit AND on receive is surely a bargain and a good indication of what we have to look forward to as SDR develops.
f5oeo
Post by f5oeo » Fri Aug 18, 2017 5:52 pm
Will receive mine next Monday...Charles do you plan to make a commit on github for the PlutoExpress ?
Post by G4GUO » Fri Aug 18, 2017 7:37 pm
Probably in a couple of weeks. I have corrected quite a few things in the project files
and put hooks in for LimeSDR so a lot of files need changing.
First I will release a 32 bit binary. I am trying to improve RB DVB-T at the moment.
I know DVB-T is not important to most people.
on8ge
Post by on8ge » Fri Aug 18, 2017 8:40 pm
Mine is ordered :-)
73's Pierre
Post by g0mjw » Fri Aug 18, 2017 9:01 pm
The main reason DVB-T isn't being used is we can't receive it yet in reduced bandwidth. If that were possible I think it might work a lot better on long VHF paths. The Lime and now Pluto might be a solution to that, though the challenge is going to be demodulating it.
Post by G4GUO » Sat Aug 19, 2017 5:53 am
The Windows drivers for the ADALM-PLUTO are here
https://wiki.analog.com/university/tool ... rs/windows
The notes on how to extend the frequency range are here
https://wiki.analog.com/university/tool ... ustomizing
You will also probably have to install the VC++ 2015 re-distributable (32 bit version)
https://www.microsoft.com/en-gb/downloa ... x?id=48145
Alpha testers will need this information when I release the test software later this weekend
(it is almost ready). I am going to try and install it on my Pipo this morning first.
I see Digikey stock is down to 32 units this morning.
G4WIM
Post by G4WIM » Sat Aug 19, 2017 7:58 am
Just ordered one myself and mentioned it to the local crew here - guess they'll all be gone pretty quickly.
73 Tim
Post by G4GUO » Sun Aug 20, 2017 10:59 am
I have removed the link while I fix an issue with DVB-S
This is a very preliminary release, read the attached notes
