Hello all,
Thought I would share the best of (so far) received images from ISS as part of the 20th Anniversary. A total of 12 images were broadcast on 145.8 MHz using PD120 SSTV.
For this experiment I used a VHF whip -> Airspy SDR -> SDR# -> Virtual Audio Cable -> MMSSTV. Towards the end of the anniversary I found the whip was better than the dual bander that I started with.
More information can be found at https://ariss-sstv.blogspot.com.au/
ARISS 20th Anniversary SSTV
- 01 201707230703.jpg (80.08 KiB) Viewed 5571 times
- 02 201707212347.jpg (75.41 KiB) Viewed 5571 times
- 03 201707210706.jpg (88.42 KiB) Viewed 5571 times
Re: ARISS 20th Anniversary SSTV
Images 4 to 6
- 05 201707222254.jpg (76.98 KiB) Viewed 5570 times
- 06 201707210035.jpg (78.08 KiB) Viewed 5570 times
Images 7 to 9
- 07 201707210039.jpg (92.86 KiB) Viewed 5569 times
- 08 201707220749.jpg (80.77 KiB) Viewed 5569 times
- 09 201707220613.jpg (79.61 KiB) Viewed 5569 times
Images 10 to 12, hoping to get better images or 10 or 11 on the next pass over head
- 10 201707220617.jpg (116.81 KiB) Viewed 5569 times
- 11 201707220259.jpg (128.33 KiB) Viewed 5569 times
- 12 201707230659.jpg (79.88 KiB) Viewed 5569 times
Took a while but I eventually got a better (cleaner) 11
- 11 201707232203.jpg (75.06 KiB) Viewed 5524 times
