DTX 1
G4DHO
DTX 1
Post by G4DHO » Sat Jul 22, 2017 11:45 am
Good afternoon Laurence
The DTX 1 boots up normally and then the top button is pressed the middle LED comes on and the device is in transmit . As part of a considered upgrade to the GB3UD transmit line up this is a minor issue and can be overcome by external means.
However the existing exciter works in a similar fashion but automatically goes to transmit after boot up , this is a useful asset as in the case of a mains failure the transmitter comes strait on, just after power is restored. Therefore I wondered if a small change in the software can easily be introduced to get the DTX1 to go automatically to transmit after power restoration instead of having to make a bit of external circuitry to achieve just this action.
No rush for a reply kind regards Albert G4DHO
G8XZD-TV
Re: DTX 1
Post by G8XZD-TV » Sat Jul 22, 2017 2:09 pm
you can set it in software to come on in either standby or tx mode
M0LDZ
Re: DTX 1
Post by M0LDZ » Sat Jul 22, 2017 3:35 pm
Well that's an easy one!
By the way, Antennair are on with another batch of DTX1's for BATC presently. So don't worry that the shop is showing low stock - more are on the way :)
Laurence M0LDZ
G4DHO
Re: DTX 1
Post by G4DHO » Sat Jul 22, 2017 8:10 pm
thank you very much I will look into things at bit further regards albert G4DHO
M0SKM
Re: DTX 1
Post by M0SKM » Sat Jul 22, 2017 8:36 pm
Hi Albert,
Page 17 of the user manual; RF Mode.
Return to “BATC DTX1”
