Hides UT-100 b and Raspberry pi
oe8meq
Post by oe8meq » Tue Jul 11, 2017 5:37 pm
Hello!
I am using Raspberry pi and Hides UT-100 b.
I could installed the valid kernel 4.4.38-v7+ and thre driver usb-it950x.ko.
But I cannot open this file or driver with make.
Then I want know with a command the setting for frequency and bandwithdh is necessary.
Please can you help.
f5oeo
Re: Hides UT-100 b and Raspberry pi
Post by f5oeo » Sat Jul 22, 2017 7:56 am
If the driver is installed, you can use https://github.com/F5OEO/it950x_cmd to test as a simple command line.
