i am looking for someone to stream gb3ud... 24/7 i can supply capture device usb a tonna 23ele a satellite rx the only thing i cant supply is coax and pc..! all you need is vmix
in 1 week the stream will shut down and will no longer be here so quick quick...!! the stream will need to be 24/7 so you need to leave a pc running 24/7 bear this in mind
i am having to shut it down due to not being able to transmit my own station..
unless someone can donate a transmit and rx filters.. 5pole tx 5 pole rx will most likely be needed then i will keep it active
regards sean
GB3UD STREAM GOING OFF
sean2e0saf
23cms AATV from io83qn ( wn68ns )
23cms DATV from i083qn ( wn68ns )
70cms DATV from io83qn ( wn68ns )
wimo shf-2344
parabeam 70cms/18ele
wimo shf-2344
Re: GB3UD STREAM GOING OFF
It's great to see that you have found a new operator, well done. 73
