RF switch PCB dimensions ?
G4WIM
Post by G4WIM » Wed Jun 21, 2017 3:32 pm
Just putting the finishing touches to my Portsdown tx, but don't currently have a RF output switch to measure fixing centres and install.
Does anyone have a drawing of the PCB showing size, hole centres and diameters etc ?
Having this info would mean I could finish the metal then install the PCB once I can order one from the BATC shop.
Thanks Tim
PS - I've had a look around and only found the schematic and parts list info.
MN-tech
Re: RF switch PCB dimensions ?
Post by MN-tech » Wed Jun 21, 2017 4:50 pm
The output switch board measures 54mm x 43.18mm.
I have a .PDF file that will print to the correct size if “Actual size’ is selected when you print. It's a bottom view so the holes will be correct if you attach it to the outside of your enclosure.
However I can't attach it here. I have sent a copy to Dave G8GKQ with hopes he will put it on the Wiki.
In the meanwhile here is a .PGN version which you will have to scale yourself.
John
Portsdown Output Band Switch Bottom..PNG (17.96 KiB) Viewed 6486 times
G4WIM
Post by G4WIM » Wed Jun 21, 2017 5:13 pm
Hi John,
thanks, as I know the pitch of the connector pins I can now easily determine all the other dimensions !
Getting to quite like the metal work aspect of putting this together :-)
MN-tech
Post by MN-tech » Wed Jun 21, 2017 5:21 pm
I hope you noticed the overall board dimensions are the first line in my previous post.
If your scaling gets those right the rest will fall into place.
G4WIM
Post by G4WIM » Wed Jun 21, 2017 5:25 pm
yep duly noted re overall dimensions - thanks
Post by G8GKQ » Wed Jun 21, 2017 9:33 pm
I've just posted the .pdf on the Wiki here: https://wiki.batc.tv/RF_output_switch
M0YDH
Post by M0YDH » Mon Jun 26, 2017 11:44 am
The PCB was an excellent drilling jig. So worth the wait.
David M0YDH
