Mystery default numbers
jmanley
Post by jmanley » Tue May 09, 2017 1:51 pm
Can anyone please advise how to get rid of random numbers in..... "edit your streams details"..... page that has suddenly appeared in the ...."stream"..... box, it does not respond to delete keys but stops my computer streaming.
John M1CNJ
G8DKC
Re: Mystery default numbers
Post by G8DKC » Tue May 09, 2017 8:14 pm
Hi John, I think I have an idea what's happening, see picture attached.
The Html is for the bottom blue space below stream and chat, as seen on many repeaters etc.
I'm sure Noel will reset this for you if you get stuck, if he gives you new details then look at his guide, probably Step 3...
http://www.batc.org.uk/Getting_Started/streamguide.pdf
Peter
Post by g8gtz » Tue May 09, 2017 8:26 pm
Hi John,
Peter is correct and I can help if needed - also take a look at this page on the wiki - it has the instructions you need:
https://wiki.batc.tv/Streaming_to_batc. ... ve_Encoder
And a document here http://www.batc.org.uk/Getting_Started/streamguide.pdf
73 Noel - G8GTZ
jmanley
Post by jmanley » Thu May 11, 2017 10:56 am
Hi Peter and Noel
With head held low I offer apologies for not obeying the rules as set out on screen.
When I first started streaming many months ago I never added a new stream consequently the stream number never changed and thought that it was a permanent feature even though instructions plainly indicated otherwise.
Many thanks for your patience.
John M1CNJ
Return to “Streaming”
