Shop update - Easter 2017
The place for announcements on the latest stock items and for your feedback on items that you would like to see in stock
Post by g8gtz » Fri Apr 14, 2017 9:03 am
Current stock / orders are as follows:
MiniTiouner:
Serit tuners = 100 on order - due early mid May.
Main PCB redesign - 10 prototype PCB arrived and being built - hope to order 100 PCBs by end of next week for early mid May delivery.
Serit adaptor PCBs still in stock.
Portsdown:
Assembled filter modulator boards = 60 on order - due early May
LO filter PCB - 100 to be ordered this week - due early May
4 Band decode - 50 more to be ordered this week - due early May
Re: Shop update - Easter 2017
Post by g8gtz » Thu May 04, 2017 5:18 pm
Update:
All the PCBs arrived - 6 days from point of order to DHL knocking on my door- amazing!
The Portsdown blank PCBs are in the shop (including the LO filter).
The next batch of 100 Serit tuners are currently on the way from Hong Kong - again with DHL, so maybe the middle of next week.
Do you need to buy one? Possibly, but look at the check list at the top of this page to find out https://wiki.batc.tv/Serit_tuner
The Version 2 MiniTiouner Serit boards arrived and are having a quick check over before released in the shop.
What's a version 2 MiniTiouner board and do you need one? Take a look here before you buy one https://wiki.batc.tv/MiniTiouner_hardware_Version_2
The 60 off assembled Portsdown Filter Modulator boards are due middle of next week but will need to be tested - not an insignificant job but we can't put them in the shop until it is done.
We are looking for volunteers to help to test the FM boards - either by meeting up with me for a day or if you have the test gear / experience it could be done at home. Process is to set the modulator balance and check MER and power output at 146, 437 and 1255 plus a quick spectrum check.
73 Noel - G8GTZ
Return to “BATC Shop”
