loading the miniTioune for the first time
mikenicholas
Post by mikenicholas » Mon Apr 03, 2017 1:55 pm
On test my mini tuner V1.3b page I have two green lights and a message
When I select test NIM I get:
Trying to get Demodulator serial number
Error: impossible to read correct value from Demod chip
any suggestions
G8XZD-TV
Re: loading the miniTioune for the first time
Post by G8XZD-TV » Mon Apr 03, 2017 8:21 pm
With both the units I've built I had problems with the usb module socket - reseating it a few times helped. Other than that I'd check the
IC that's under it is the right way round and no bent pins. Failing that I'd run an iron round the usb module socket pins and check all those joints
are ok. Other than that there's not too much to go wrong!
73 Ian.
mikenicholas
Post by mikenicholas » Tue Apr 04, 2017 7:29 am
Ok Thanks
all the hardware looks good just don't know where the demod chip is
Will try it on a working system next with G4KLB
thanks Mike G3TOI
Post by g8gtz » Tue Apr 04, 2017 7:33 am
Hi Mike,
Demod chip is in the tuner.
Which tuner / NIM are you using?
Suggest you check the volts on the various PSU rails then maybe ask Colin if you can swoop out the USB module / NIM to see if they are faulty - we've not had any board faults so likely to be joints or PSU related.
73 Noel
mikenicholas
Post by mikenicholas » Tue Apr 04, 2017 11:55 am
OK Noel Thanks
Am going to Colins Wed with laptop and RX it's a Sharp Tuner
and will find out if it is hard ware or software
I got the FT2232 h from batc set up
Mike G3TOI
