PI to GPIO to screen connections
G4HTZ
Post by G4HTZ » Tue Mar 21, 2017 4:38 pm
Gradually getting the bits together for the portsdown...tx board , gpio board are here ..awaiting PI and screen and LO to arrive.
Question is ....what breakout cables and connections do I need to go between Pi , GPIO board and screen ...believe a double header is required from GPIO board to screen ??
I know there's a link to adfruit ...but it says out of stock ...Farrell want a surcharge of £15 to order adfruit parts from USA.
Lots of parts on eBay ..but unsure what I need ...please answer here.
Mainly intend to operate 70cms as within 146mhz exclusion zone here in Essex .
Steve G3GHZ
Canewdon Essex JO01IO
5665 ATV FM
Re: PI to GPIO to screen connections
Post by g8gtz » Tue Mar 21, 2017 5:02 pm
Hi Steve,
I do agree we are a bit light on documentation on actually connecting up the modules but the core team has not had time - there is a section here https://wiki.batc.tv/Assembling_Portsdo ... akout_card but it is not a wire by wire description.
It is something I'm looking at but it's actually quite easy and is something everyone else can contribute to.
The stacking header is available here http://www.robotshop.com/uk/2x20-stacki ... GwodDIkDGQ
73 Noel
G4HTZ
Post by G4HTZ » Tue Mar 21, 2017 5:15 pm
Thanks Noel for link
Yes know you guys are busy and have other lives apart from ATV :D
Been going round in circles on the wiki , eBay , Farrell today ...not sure what cables I need ...yes looks simple but not having the pi and screen here not sure what connections are on the boards ....
Perhaps people could post a few links here to what they are using and where they got it ...then it could be put on the wiki site .
Steve
Steve G3GHZ
5665 ATV FM
DG8KD
Post by DG8KD » Tue Mar 21, 2017 7:11 pm
I took this one from ebay:
http://www.ebay.de/itm/112248788896
Took a few days from China.
Rainer
Post by g8gtz » Wed Mar 22, 2017 1:10 pm
There is now a Portsdown module interconnect diagram on the wiki page https://wiki.batc.tv/Assembling_Portsdown
Hope this helps - more to come...
G4HTZ
Post by G4HTZ » Wed Mar 22, 2017 6:49 pm
Thanks for the update Noel ...helps me a lot :D
Steve G3GHZ
5665 ATV FM
G4HTZ
Post by G4HTZ » Sat Mar 25, 2017 7:24 pm
Sorry another query re inter board wiring.
On gpio drawing Noel put on wiki , it shows JO4 on GPIO board linking to the ADF4351 .
Where does connection 5 on JO4 go to ....no line on drawing.
Also on ADF4351 it's marked 5v .....all the ones I've seen are marked 3.3v .
Still waiting for ADF4351 to arrive from china ...zzzzzzzzzzzzzzzz
Cheers
Steve
Steve G3GHZ
5665 ATV FM
M0SKM
Post by M0SKM » Sat Mar 25, 2017 8:22 pm
Pin 5 JO4 is the 5volt supply to the ADF4351.
Mine runs on the 5volts from that connector; there's an on-board regulator on the ADF4351 board.
The main power connector can take between 4 and 9 volts.
I struggle with the waits from China too; bite my nails to the quick. :cry:
Steve
G4HTZ
Post by G4HTZ » Sat Mar 25, 2017 8:32 pm
Thanks Steve
Got most of the bits now or on there way from eBay
Ordered the ADF4351 from china ...then found there's a supplier on Guernsey on eBay ...live and learn
Thanks for the info
Cheers
Steve
Steve G3GHZ
5665 ATV FM
