Home Build issue
Home Build issue
Hi Guys
I have been following the Portsdown from down under and started construction, one issue I hope you can clarify. The filter components as per cct diagram and parts list vs photos seen here. The first photo of a completed early board I have attached but the component layout of the filter differs from the parts list and diagram can some one confirm the attached photo is old and obsolete ? I have seen a few photos on twitter BATC and they seem to match the component list and diagram
regards Rob ZL3TCM Christchurch NZ
Edit by G8GKQ: This photo is of an early, incorrectly assembled, board and should not be used as a guide. Photos of correctly constructed boards are in subsequent posts on this Forum. Rob - thanks for bringing this to our attention and we're sorry for the confusion that it has caused!
- 1109px-2-3_Filter-Modulator2.jpg (181.45 KiB) Viewed 9326 times
Re: Home Build issue
Where do you think it is different?
The board pictured certainly has the filter components in different locations to mine. My higher symbol rate bandwidths look awful and I've been at a loss as to why. All parts are fitted as per the BOM locations.
Which is correct; the E and G inductors are transposed?
yes my issue was the location of the inductors rows G and I would assume as well that the capacitors maybe also installed differently ( hard to impossible to tell from a photo )
regards rob ZL3TCM
regards rob ZL3TCM
We clearly have an issue here, as my board looks different I'll investigate tomorrow and post back.
I agree Dave yours is a built by the BOM list and overlay
The circuit diagram and parts list are correct, the photo was of the very first prototype (Where we discovered the fact the filter components were transposed)
thanks for the clarification, wonder why Dave G8GKQ isn't having great sucess with his filters then
regards Rob
regards Rob
Hi Rob,
There's a little confusion; it's me that feels the filters on high symbol rates are not working well. As far as I know Dave doesn't have an issue with his Portsdown board.
I'm waiting for analyser pictures of the three higher symbol rates before looking into it any further.
PM replied to.
73 Steve
PM replied to.
73 Steve
Hi Steve,
I've put some pictures taken from testing at 333Ks on the wiki here: https://wiki.batc.tv/Filter_Modulator_V ... ifications
It's currently still on the test jig - what else would you like to see?
