Repeater interference by drones/quadcopters
GB3YT has recently been suffering from interference from a local drone/quadcopter using frequencies very close to the repeater input frequency. The signal is analogue and is close enough to open the repeater causing spurious transmissions to take place.
I am interested to know if any other repeaters are suffering from similar types of interference?
73 Kay, G8NZR
73 Kay, G8NZR
- G1LPS Terry
Re: Repeater interference by drones/quadcopters
Hi Kay
It accesses GB3KM also on 1280mhz
Regards
Terry G1LPS
Regards
Terry G1LPS
Hi Kay,
Yes we get this down at GB3GV, 2 or 3 times a month, never a clear picture to see the ground below,
probably very close but on the filter edge, the 1249 Rx has afc so follows the signal.
Peter
Peter
Hi Kay,
Yes we have had quadcopters accessing GB3TZ from the very local Dunstable Downs. They seem to have stopped now; probably due to the gliding club at the foot of the downs. I guess they have been warned off.
Steve
Steve
Thanks for the comments so far - Looks like we are not alone then!
I have been unsuccessful in a back door approach to Ofcom so suggest you all fill in this form - seems to be the only one remotely relevant:
https://ofcomforms.secure.force.com/for ... nersReport
Suggest you mention that whilst it is causing interference to your repeater you are very concerned that it may also be causing interference to safety of life systems operated by the primary user in this band.
In my naivety I thought the GV interference was coming from a hill used for leisure purposes by the locals.
Yesterday I managed to beam onto the signal at 1.239Ghz, read the grid reference from the P5 picture and found it 25 miles away to the north up in the Derbyshire hills
Will pass this on to Nigel GV's Keeper.
Looking at the 50-60 Miles between GB3YT and GV possibly the same machine, usually on mid to late afternoon?
Peter
Peter
I think the YT interference is local as I'm sure we recognised the River Calder running through Mirfield. This is about half a mile away from the repeater. From what I have read, the drone video transmitters only radiate 800mW, so I don't think its going to be the same one over that sort of distance - although it is often mid afternoon when it happens. Since the drone frequency is slightly off YTs receive frequency, our picture is very grainy and difficult to see the GPS co-ordinates.
I'll take a look at the form Noel suggests and get one into Ofcom.
73 Kay
73 Kay
