Activity Planned for Thursday 29 September
Post by G8GKQ » Mon Sep 26, 2016 10:15 am
G4GUO, G8GTZ and I are planning some 437 MHz DVB-S2 tests on Thursday 29 September from 1100 onwards.
I will be on Portsdown Hill, above Portsmouth, Charles will be at his home QTH near Worthing and Noel will be /P somewhere tbd. Dave G0EID may also be active from East Grinstead.
Talkback will be on 144.75 and Noel and I may also have 10 GHz RB-TV capability.
Please post here if you are likely to be available!
Re: Activity Planned for Thursday 29 September
Post by G4EWJ » Mon Sep 26, 2016 8:09 pm
The tropo forecast looks favourable for Tuesday evening. I might pop out to North Wales, with a good takeoff to the North.
G8DKC
Early Wednesday Morning Obliged
Post by G8DKC » Wed Sep 28, 2016 8:48 am
Tuesday evening looked promising 144.750 good through ZZ and HV, but when switching off at 23:00 nothing getting through on 437Mhz.
All looked up at 5:50 this morning, yet again to the South, ZZ still avoiding my signals, have a 19 element Yagi for 437Mhz, that must go up.
Good signals into GB3HV on 437Mhz 2 m/s, turned power down to 5W over 163Km from my 3 Element Yagi:-)
Thanks to GB3TZ being streamed by GB3BH, monitored my signals to TZ at 104Km, my Tropo path to TZ can be more challenging than to HV.
Back to GB3HV, switched to RB-TV (437.5Mhz 333 m/s 7/8 Fec) via Skype DTMF and was in, turned the power down to 10W before losing lock.
North West to North East is difficult from here due to very local hills, but it is useful having GB3GV on the doorstep at 50M higher.
Peter
GB3HV 5W
GB3HV 5W
437 HV.jpg (70.04 KiB) Viewed 8765 times
GB3TZ 100W
GB3TZ 100W
TZ streaming Via BH-01.jpg (62.47 KiB) Viewed 8765 times
GB3HV 10W RB-TV
GB3HV 10W RB-TV
437 RB-TV HV 10W.jpg (89.21 KiB) Viewed 8765 times
M0SKM
Post by M0SKM » Tue Oct 04, 2016 10:40 pm
Any follow-up?
How did the tests go? I saw a bug was found in the DATV Express S2 code. Can I take it you were also trialing Minitioune V0.5, is it good to go?
G8DKC
Re: Activity Planned 29 September S2 Tests
Post by G8DKC » Wed Oct 05, 2016 7:25 am
Hi Steve and Dave.
I had seen testing DVB-S2 in workshop a picture behind picture artefact, but then was ok.
Heard about something like this over .750 talkback on the day?
Was playing with various settings etc. Haven't seen this again, any thoughts?
Great picture though, more tests to follow.
Peter
Post by G8GKQ » Fri Oct 07, 2016 3:15 pm
Hi Steve
Initial DVB-S2 test results and discussion here: http://batc.org.uk/forum/viewtopic.php?f=15&t=4709
More tests planned soon.
M0SKM
Post by M0SKM » Sun Oct 09, 2016 7:50 am
Thanks I had found your comprehensive post; a useful start point for the uninitiated. I can't wait for the release of DVB-S2 capable Minitioune.
Steve
M0SKM
