Hardware for EsHailSat2
oe7dbh
Post by oe7dbh » Fri Aug 05, 2016 4:03 am
OE Forum page about it: http://www.oe7forum.at/viewtopic.php?f=42&t=468#p1663
Potential hardware components for Es'HailSat or other terestrial use.
For the satellite reception.... PLL LNB
more information here: http://www.oe7forum.at/viewtopic.php?f= ... =135#p1519
To send, UP Converter:
for DVB , CW and SSB signals....
and with DVB signals... http://www.oe7forum.at/viewtopic.php?f= ... =375#p2050
more information here: http://www.oe7forum.at/viewtopic.php?f= ... =150#p2045
Hopefully no more start delays ;)
vy 73 de Darko OE7DBH
oe7dbh@tirol.com
been translated into English with google
oe7dbh
Re: Hardware for EsHailSat2
Post by oe7dbh » Sat Sep 24, 2016 9:13 pm
...another one LNC for receiving :
Output1 or Port1 for DVB-S
Output2 or Port2 for SSB - CW on 70cm Band
88,00 Euro kit including: LNB , T bias , Adapter F male to BNC female
oe7dbh
Post by oe7dbh » Wed Mar 22, 2017 1:38 am
http://www.ebay.com/itm/BU-500-13cm-Up- ... 33ca9b00b4
9a6rzn
Post by 9a6rzn » Sat Jun 09, 2018 10:24 pm
HiDes UPconverter made special for EsHail2 HamRadio Transponder...
BU500 Ver.2 and Ver.3 "ready for use" in the housing comes with measurement protocol.
G1BVI
Post by G1BVI » Mon Jun 11, 2018 12:37 pm
Input Drive Level?
On the image showing the DUT hooked into an analyser the drive level is shown as 0.5mW which is about -3dBm.
However the drive on V1 and V2 is -10dBm which is 0.1mW and the drive on V3 is +10dBm which is 10mW.
Was the original DUT being over driven or under driven I wonder.
The output of a FT818 is about 6W call it 38 dBm. (We all forget to switch the power down at some point!)
a 30dB attenuator will therefore be required to drive the v 3 unit .
I think my Maths is correct.
For a pi circuit
this gives values of 53 ohms and 800 ohms.
The 53 ohm input resistor would need to made up of several to get to this value and be able to sink the power of 6W.
I tried lowering the value to 50 ohms as these are easy to purchase at higher wattages but the return loss gets worse.
A quick google search however found some cheap ready made attenuators.
Roll on pay day :-)
Roll on launch date !???????
Nick
G1BVI
9a6rzn
Post by 9a6rzn » Mon Jun 11, 2018 9:15 pm
Picture above shows the inner one of the first prototypes, with more than allowed input Levels ( without Input attenuator and 0,5mW Signal ). Nevertheless clean output signal.
We have a head on our shoulders to think about that ;)
a 30dB attenuator will therefore be required to drive the v 3 unit for SSB-CWYES
For digital Television: attenuator value depends on TX output signal Level , there are two versions UPconverter available :)
9a6rzn
Receiving LNB from Austria
Post by 9a6rzn » Thu Sep 27, 2018 1:13 pm
10GHz Octagon down converter...
LNB liste batc.png (135.52 KiB) Viewed 25213 times
Post by g0mjw » Fri Sep 28, 2018 8:05 am
TCXO at 2ppm, 10ppm normally? That means 20kHz to 100kHz error. OK for DATV but we are going to need a lot better stability for SSB/CW than 2ppm. Any way to develop an LNB for 10 GHz that takes a 10MHz reference input?
YL3AKC
Post by YL3AKC » Fri Sep 28, 2018 9:01 am
Even if I am lazy, I am working on this... ;)
Post by G4GUO » Sat Sep 29, 2018 8:32 am
From Twitter it seems people are using these http://www.df9np.de/page4.html
