23cm atv
g7vnpkevin
23cm atv
Post by g7vnpkevin » Tue Jun 28, 2016 8:46 pm
Hi All
After a lot of a work got 23 cms to work controller and rx board from MobiComm I have a lot of white on picture any i dear how to fix it just started to test as next is to try for gb3pv out side of Cambridge will report back after test at weekend how do you get test card to transmitter and were can i find temp pleats from hope to make it all portable when done just got to work out power supply as need 12v+ and 13.8v+ plus 8v= so still got to build power box yet
The set up here is a MobiComm receiver and controller TX is a TSIM Board
I have made a beam 19 ele yagi and a dish with qued for receive
from Kevin g7vnp
G8ADM
Re: 23cm atv
Post by G8ADM » Tue Jun 28, 2016 10:15 pm
That sounds great. I look forward to hearing more...
g7vnpkevin
Re: 23cm atv
Post by g7vnpkevin » Mon Jul 18, 2016 11:02 pm
Hi All
Done more testing over the last few weeks and found the transmitter be off frq by 15 so if you are tx on 1240 you are receiving on 1225 any one found this on mobiComm boards any help will be welcome
from Kevin G7VNP
