Ground strap.
Ground strap.
Post by G4EWJ » Mon Aug 17, 2015 10:10 am
Peter G3PYB noticed that that he was getting a small amount of corruption on the transmitted data and found that it could be cured by improving the ground connection between the RPi and DT pcbs by fitting a short ground strap between the exposed pad under the Local Osc legend on the DT pcb and the case of the network connector on the RPi pcb.
Return to “DigiThin”
