big carrier in the middle of my modulation
F6DZP
Post by F6DZP » Tue Jul 07, 2015 8:56 am
I have started for the first time my Digithin this morning.
- Pidatv image 1.2.1
- raspberry model B
it seems to modulate well, but I have a big carrier remaining.
input is 437MHz . I try between -10 and -20 dBm, it changes nothing.
first test.jpg (117.47 KiB) Viewed 21202 times
Have you an idea to fix this?
thanks
Jean-Pierre F6DZP
Re: big carrier in the middle of my modulation
Post by g8gtz » Tue Jul 07, 2015 9:54 am
Hi jean Pierre
Looks like the digithin isn't actually getting the right data stream from the Rpi. With an LO of -20 DBm the output when correctly modulated should be 0dBm.
What's the LED doing? It should be flashing every second - if it's not that's the problem and you need to check you're running 333Ks and if you are playing a TS file it is recorded at right bit rate...
F6DZP
Post by F6DZP » Tue Jul 07, 2015 10:21 am
I have a 20dB attenuator before my spectrum analyzer.
led flash every second.
All seems to work, but there is that high LO signal that remain..
I suppose I must check the level of IQ that go in the modulator, perhaps they are too low?
Jean-Pierre F6DZP
Post by G4EWJ » Tue Jul 07, 2015 11:04 am
Check the level of I and Q just after the analogue filters: junction of C17-R16 and junction of C20-R17.
The levels should be about 120mv pk-pk.
Hopefully it's something simple. I have also seen that pattern if the modulator is faulty. If it's the one I gave you in Portsmouth, I think that came from the Ebay batch from Israel.
F6DZP
Post by F6DZP » Tue Jul 07, 2015 11:33 am
I have only 40 mv pk pk at C17-R16 junction.
Jean-Pierre
Post by G4EWJ » Tue Jul 07, 2015 12:53 pm
What values do you have for R21 and R25? They are 'select by test' to give about 120mv pk-pk. 1k seems to be about the required value.
Even that would not explain the very low level of the modulation, so it must be something else causing it.
F6DZP
Post by F6DZP » Tue Jul 28, 2015 11:48 am
I have changed the modulator by a new one sent by Brian (thanks).
Now this problem is fixed.
when I receive on 437Mhz, max MER is 27dB.
Tutioune1600 digithin 437 SR333 MER27dB R500.jpg (476.22 KiB) Viewed 20983 times
using R21=390 ohms, 120mV I have now 29dB MER
Jean-Pierre F6DZP
Return to “DigiThin”
