Loads of ATV stuff for sale
G4HTZ
Post by G4HTZ » Thu Jan 22, 2015 3:10 pm
I am moving to Spain EA5 land in the next 6 months or so so am selling all my ATV equipment, some of it never used .
This is the 1st list ...loads of quality cameras , mixers, test card generator, monitors to follow .....
DTX1 fully working £360
75w 70cms linear amp low level drive from DTX1 to full output ..no relays 12v £120
Bert moddeman PE1RKI 23/24cms amp...low level drive from DTX1 gives 100mw out £65
Bert modderman PE1RKI 23/24cms amp ..100mw in about 12w out DATV...Bert put a attenuator on input to allow 100mw drive as amp only requires 25mw ...see his website ..new never used ..£120
DB6NT mast need 23/24cms pre amp model MKULNA132A2TM ...only rarely used outside £100
DG0VE 70cms to 23/24cms up converter PLL ..brand new never used £85
175w 23/24 cms linear amp with 26/28 v PSU ...no relays ..10w max in £375
G1MFG plantinum 23/24cms boards TX RX and controler...never wired up so unused £110
Wimo 28ele 23/24 cms yagi ...rarely used £95
Sevenside 23/24cms yagi ...looks unused £30
DB6NT 10ghz 250mw ATV TX on 10450 but tuneable plus minus 25mhz £150
Basband modulator with 6mhz intercarrier sound for db6nt type tx £50
10ghz LNB.9ghz LO..low noise will fit sky dish £15
10ghz slotted waveguide antenna ..no Radom / cover WG16 flange £50
C band 3.4 ghz LNB ..brand new never used ..ideal for new 3.4ghz repeaters £15
Comag sat RX £25 with remote.
All plus postage or collect from nr Southend essex
Please email for further info / pictures essexsteve@icloud.com
Steve G4HTZ
ASHEN nr Sudbury JO02GB52 90m ASL
PORTSDOWN and a RYDE …
G4HTZ
Re: Loads of ATV stuff for sale
Post by G4HTZ » Thu Jan 22, 2015 6:47 pm
10ghz RX LNB and 10ghz waveguide antenna sold
3.4ghz LNB and comag RX reserved for collection
DG0VE 70cms converter sold
175w 23/24cms amp sold
23/24cms 10w amp sold
g1MFG boards sold
DB6NT mast head amp sold
DTX1 sold
23/24 cms 100mw amp sold
10ghz db6nt tx and baseband modulator sold
Steve G4HTZ
glen_turner2002
Post by glen_turner2002 » Wed Mar 25, 2015 5:25 pm
Hi, Could you please tell me if you have the following items still for sale?
Thanks,
Regards, Glen - G7MNP
