GB3KM New logic installed
Locator: IO94EQ
Inputs: 6 X Inputs available (any four available simultaneously in quad picture and sound)
1.280GHz - FM & Digital 4m/s
2.328GHz - FM - Omni Alford Slot
2.388GHz - FM - Omni Alford Slot
10.315GHz - FM & Digital 4m/s Omni Slotted Waveguide
Outputs:
2.440GHz - Omni Alfort Slot - FM -
10.065GHz - Omni Slotted Waveguide - FM
3.406GHz - Omni Digital DVB-S 4m/s
Watch Live at: http://www.batc.tv/ch_live.php
No Activity night as of yet... Activity is usually Mid Afternoon / Late Evenings
Web site: http://www.m0dts.co.uk/gb3km/index.html
G1LPS Terry
Post by G1LPS Terry » Mon Mar 10, 2008 10:44 pm
The new logic built by MODTS Rob has been installed and is functioning well. It currently allows for 4 inputs. the DVB receivers will be on the DTMF
The DTMF MENU was added yesterday to display the menu send * on any of the repeater inputs. 2 meter DTMF control will be added later.
More of the recently added features will be activated soon.
ENJOY
Terry G1LPS
G1LPS Terry
Re: GB3KM New logic installed
Post by G1LPS Terry » Sun Mar 16, 2008 10:01 pm
GB3KM's main Rack
GB3KM's main Rack
KM RACK.JPG (649.24 KiB) Viewed 64496 times
G1LPS Terry
Post by G1LPS Terry » Sun Mar 16, 2008 11:32 pm
GB3KM DTMF.zip
GB3KM DTMF CONTROL by Rob M0DTS
(294.84 KiB) Downloaded 1842 times
Robert has just made a nice DTMF control pad check it out here and on his web site m0dts.co.uk
G1LPS Terry
Post by G1LPS Terry » Sun Apr 20, 2008 8:17 pm
The DTMF Commands that have been activated are:-
*1280# view 1280mhz
*2328# view 2328mhz
*2388# view 2388mhz
*10315# view 10315mhz
*15# view quad screen
*16# view picture in picture
*17# view pc streams etc.
*18# set quad and picture in picture (followed by desired views)
*58# s meters on
*59# s meters off
more to follow soon !!
Enter them into Robs DTMF program above and press save.
cheers and beers Terry G1LPS
G1LPS Terry
Post by G1LPS Terry » Sun Apr 20, 2008 8:23 pm
Sending an DTMF * by itself displays the menu for 5 seconds.
otherwise it is displayed for 2 seconds as each command is sent. ;-)
trevor
Post by trevor » Sun Jul 13, 2008 5:57 pm
Terry
Would you consider streaming your repeater to www.batc.tv
Now it running should be the least delay of all streamers for the UK
Trevor
G1LPS Terry
Post by G1LPS Terry » Fri Jul 18, 2008 11:28 pm
Hello Trevor
The KM stream is provided by Rob M0DTS speaking to him today he indicated this was his intention. so hope you see us there soon. Robs stream picture is remarkable considering the distance and that the 10ghz rx dish at his end is indoors in a room without windows!!!!! dont know how it works? Just goes to show try anything.
Regards
Terry
Rob any comment ?
Return to “GB3KM”
