Amino 125
ross1
Amino 125
Post by ross1 » Thu Jan 02, 2014 12:55 am
Greetings All
I am after a firmware image to suit an Aminet125 or Amino 125.
I have one that hangs during bootup at the 'loading' page.
I believe it is trying to load a new image as the previous one has been erased.
I don't think there is any way to recover the original firmware but I stand to be corrected.
Thanks for reading this, happy New Year to all
Regards
Ross VK3CE
Re: Amino 125
Post by M0DTS » Thu Jan 02, 2014 9:39 am
Hi Ross,
I did some firmware re-loads a few years back on these.. not an easy task if i remember correctly but it can be done if you have some patience!
This will help you:
https://forum.videolan.org/viewtopic.php?f=4&t=38889
I used the image on the last message, google should be able to find a copy somwhere still i'm sure, otherwise i may stil have a copy.
ross1
Re: Amino 125
Post by ross1 » Thu Jan 02, 2014 9:53 am
Thanks Rob,
I have downloaded the file but I am don't think it is suitable as I have a model 125 not a 110.
Regards Ross
Re: Amino 125
Post by M0DTS » Thu Jan 02, 2014 10:27 am
Ah yes different model..
Sorry i cant help any more, it was only the 110 i played about with.
Maybe it will accept that version of firmware, you could try that if nobody else has any ideas but normally firmware is very specific.
If you're very lucky you could find a place where they are still used and steal their network connection for a few minutes ;-)
Return to “Streaming”
