Digilite-ZL
markaren1
Digilite-ZL
Post by markaren1 » Wed Jul 18, 2012 6:33 pm
Hi All,
Several people at the group have asked about progress of the project. Below is a message that was posted to the pvrusb2 mailing list, who developed the V4L drivers for the MPEG encoder that I am using.
Hopefully it gives an update in roundabout terms, and also explains my continued hair loss :)
-Mark
Hi All,
I am working on a small, low power embedded digital TV project (see http://www.idesignz.org/DigiLiteZL/DigiLiteZL.htm, and associated FPGA modulator http://www.idesignz.org/DigiLiteZL_FPGA ... L-FPGA.htm). One of the next steps of the project is to hook a real-time MPEG2 video encoder up to the system, running at a suitably low rate (maybe 1 or 2Mb/s total stream rate). The power budget for the system does not allow for a PC, hence the desire to use a small embedded system.
An HVR-1900 MPEG encoder is at hand, but only composite video and audio inputs are required. This product appears to contain a Conexant CX23416 MPEG2 audio/video encoder, a CX25840 PAL/NTSC video decoder, and a Cypress FX2, or FX2LP USB interface. The unit has misc stuff associated with RF tuner etc, hopefully these can be ignored.
Moving on to signal flow: an external PAL video source will be plugged into the HVR-1900, the HVR-1900 will be plugged into a custom dsPIC33EP512MU810 board (which has a USB 1.1 host). The dsPIC has the job of initially loading required firmware into the HVR-1900 then selecting the required encode mode and translating the incoming real time MPEG Program Stream into Transport Stream. This data will then be transferred via a new parallel interface to the FPGA DVB-S modulator (USB is currently used).
So far the PVR-1900 has been attached to Ubuntu Studio 10.x via a USB 1.1 hub, and it has been confirmed that the whole chain can generate a 1Mb/s PS using V4L. This was all rather easier than expected and worked pretty much off the bat, so well done.that team.
Having spent some time playing with a Cypress FX2 (CY7C68013) USB interface dev kit, it appears that the FX2 can accept firmware over the USB port, and run from it's internal 8k (FX2) or 16k (FX2LP) RAM using vendor command 0xA0. A second stage boot loader (vend_ax) is required if external RAM is required. Some amount of cleverness involves the device re-enumerating itself from default VID / PID (0x04B4 / 0x8613) once code has been loaded, so that alternate drivers can take over the boot and control process. It also appears that DID is used to differentiate the FX2 (DID 0x000x) from the FX2LP (DID 0xA00x).
So the next challenge is to completely understand all steps required to boot up a PVR-1900. From then, an understanding is required how to configure and use the booted device.
At a guess, boot sequence is something like:
1) PVR-1900 is plugged into the host (dsPIC)
2) host registers and enumerates the FX2 device within the PVR-1900 using VID 0x04B4, PID 0x8613
3) host downloads FX2 firmware (or second stage loader vend_ax) using vendor command 0xA0
4) host releases FX2 8051 from reset, new code re-enumerates using alternate VID / PID combination
-- at this point, the FX2 8051 is running a boot loader that will allow code loading of CX25840 and CX23416 --
5) host loads CX25840 firmware (possibly using two wire interface)
6) host loads CX23416 firmware (not a clue)
7) host commands CX25840 to select video standard and input source
8) host commands CX23416 to select MPEG encode profile, bit rate etc.
9) host commands CX23416 to start encoding
10) host fetches buffers of MPEG video using BULK transfers over EP2 or EP6 (?)
11) host translates PS to TS, sending output video to FPGA via parallel interface
12) repeat from 10
Notes:
13) is BT565 is used as video path between CX25840 to CX23416, if not, then what ?
14) looks like Linux uses v4l-pvrusb2-73xxx-01.fw (16,384 bytes) to load into FX2
15) looks like Linux uses v4l-cx25840.fw (16,382 bytes) to load into CX25840
16) looks like Linux uses v4l-cx2341x-enc.fw (376,836 bytes) to load into CX23416
Any corrections, pointers to relevant web pages, or other help to start filling in the great voids of understanding will be most appreciated.
Many thanks,
Mark
PS Phew !
