Hauppage HVR1100
pcossins
Hauppage HVR1100
Post by pcossins » Mon Apr 23, 2012 8:44 am
Has anyone had any luck getting Digilite to work with a HVR1100 card ?
If so, can you provide details.
Peter VK3BFG
Re: Hauppage HVR1100
Post by G4EWJ » Mon Apr 23, 2012 4:35 pm
As far as I can see, the HVR1100 does not have a hardware MPEG-2 encoder. You would need a software MPEG-2 encoder and probably a much faster PC than DigiLite with a PVR-150 requires. Have a look at the threads by F6DZP about this.
I've successfully used an HVR-1300, which has a hardware MPEG-2 encoder.
pcossins
Post by pcossins » Tue Apr 24, 2012 10:09 am
Thanks for that Brian .... it does have the Çonnexant MPEG Chip so I thought it may have been suitable. The supply of suitable cards seem to be drying up. I am trying to get a few more people on digital here in Melbourne. Peter VK3BFG
Post by G4EWJ » Tue Apr 24, 2012 12:45 pm
That's strange - I can't see them fitting the Conexant chip and then disabling it.
I was working from this data sheet. Do the model numbers or pcb layouts give any clues?
I found it very awkward to get the drivers installed. It wouldn't do 352 x 576 and I seem to remember some problem with GBPVR at lower symbol rates. It worked fine at 4MS, 720 x 576.
http://uk.ts.fujitsu.com/rl/servicesupp ... 300_uk.pdf
Return to “DigiLite”
