HamTV Reception Reports
Re: HamTV Reception Reports
Post by G8GKQ » Thu Aug 14, 2025 10:48 am
Signals strength seemed similar to immediately after switch-on to me.
G4IMO-TV
Post by G4IMO-TV » Thu Aug 14, 2025 12:16 pm
Thanks Dave. I will check the tracking next week ( too cloudy today ) and measure the Sun Noise again.
Nick
G4IMO
g4hiz
Post by g4hiz » Thu Aug 14, 2025 1:26 pm
Hi all,
unfortunately in the UK at least, the same band that the ISS downlink uses is also used for mobile phone communications and I have 3 masts within 2km of my house. The snap shot shows a max-hold display over about 20seconds, the output being from my S-band LNB, with the reference level at-20dBm. In addition, the top end of the spectrum display shows the local WiFi signals. Good front-end linearity is advised but a TDD signal appearing on top of the ISS downlink is always a possibility. The ISS downlink is usually centered at 1555MHz on my display, as shown below.
Having said that, reception was good yesterday.
Jen
Band Occupancy.jpg (1.48 MiB) Viewed 7059 times
g4hiz
Post by g4hiz » Fri Aug 15, 2025 7:51 am
Liborio,
In case you were wondering, the ISS pass at 08.46 BST in the UK showed the ISS Tx functioning. This would have been your pass at approx. 08.07.
Jen
G4IMO-TV
Post by G4IMO-TV » Fri Aug 15, 2025 8:02 am
Jen - what are the vertical graticule calibration squares ? 5dB per square making the signal 15dB above the noise floor?
I will try and do a screen shot at the 10:17 pass today.
Nick
G4IMO
G4IMO-TV
Post by G4IMO-TV » Fri Aug 15, 2025 12:03 pm
Thanks Jen for the info.
I checked the Sun tracking and it was spot on also the Sun Noise measurement was the same at 2.5dB.
The 10:17 pass today was the strongest I've ever received it at D9 MER 10.2. The only difference to the setup was I had the Nooelec converter in circuit to down convert to 895Mz so I could monitor the signal as the ISS passed. I did'nt see any interference on 2395Mhz but there was some strong signals further up the band so a Filter at a later date, might improve the lock time of the receiver.
Anyway happy with the results today, the signal was about 11dB above the noise floor on a 75 deg max elevation. Why I got such poor results on Wednessday I just don't know.
Screenshot (195).jpg (665.62 KiB) Viewed 6933 times
IU2KAC
Post by IU2KAC » Fri Aug 15, 2025 12:45 pm
Guys, after six days I managed to get some reception, getting a D3 with a decoded signal.
Setup used: 80 cm fixed dish + 30 dB LNA.
Liborio,IU2KAC
https://imgur.com/a/Hvdc5Fz
https://imgur.com/a/XwwPdff
EA6WQ
Post by EA6WQ » Fri Aug 15, 2025 5:29 pm
Hi everyone,
3rd Rx of HamTv from ISS today.Same setup, QO-100 13cm patch antena as a feed, 120cm PF dish , 36db gain DG0VE LNA, 35mts of Sat coax cable,
Minitiouner V2 Pro.
The pass started at 14:32:44 with 58º max elev north-east to soth-east, starting decoding video at about 25º of elevation for about 4 min with ups and downs , max Mer was 12 , D9.
Weather was bloddy 36º hot ...
I also measured the tracking accuracy poiting to the sun , nearly hitting the target in the middle of the dish...
Tom, EA6WQ/KE0KQT
suntracking test.jpeg (98.5 KiB) Viewed 6890 times
3rd HamTV ISS RX.jpeg (494.68 KiB) Viewed 6890 times
g4hiz
Post by g4hiz » Sat Aug 16, 2025 1:40 pm
Hi all,
Reception today was interesting as 2 dropouts were seen during an otherwise very strong pass. One can only conclude that this was possibly due to mobile phone interference arising from nearby masts, as spikes can often be seen dancing up and down the spectrum.
Parameters: 09.35 BST, 90cm prime focus dish with a POTY feed and S-band LNB, 83 degrees elevation, static pointed North.
Time Rx locked (apart from brief drop-outs) 20s, with video for about 17s.
Wx slight drizzle at 16C.
Max signal D15.
Note that the Spectrum Analyser clock is incorrect. If anyone can tell me how to change it easily, I'd be interested to hear.
Jen G4HIZ
EA6WQ
Post by EA6WQ » Sat Aug 16, 2025 2:39 pm
Hi everyone,
4ht Rx of HamTv from ISS today.Same setup, QO-100 13cm patch antena as a feed, 120cm PF dish , 36db gain DG0VE LNA, 35mts of Sat coax cable,
Minitiouner V2 Pro.
A pass with 74º max elev north-east to south-east, starting decoding video at about 30º of elevation for about 5 min, with less ups and downs than yesterday.
Maximun signal strength was Mer 18 - D16 , the hiest of all tracked passes.
Weather was pleasent fresh 25º
73's from Tom, EA6WQ/KE0KQT
4th ISS HAMTV RX.jpg (473.06 KiB) Viewed 6748 times
Return to “ARISS HamTV”
