Customising the Ryde information display
Philippe
Re: Customising the Ryde information display
Post by Philippe » Sun Jun 11, 2023 6:10 am
Hello
I would like on the F5ZMG relay to permanently display the MER and RAPORT info I used the modifications that the OMs told me to do but after modifying the config.yaml file after reboot still nothing on the screen
Where is my mistake? I use WINSCP
Thanks for any information you can give me.
73 Philip F5AOD
osd:
    timers:
        USERTRIGGER: 10
        PROGRAMTRIGGER: 10
    active:
        MUTE: null
        SIGLEVEL: null
        REPORT: null
        POWERLEVEL: null
        PROGRAM: null
        FREQ: null
        VOLUME: null
        BW: null
    inactive:
        MUTE: null
        REPORT:
            datum: TR
            x: 0.01
            y: 0.00
            w: 0.15
            h: 0.15
        POWERLEVEL:
            datum: TR
            x: 0.15
            y: 0.00
            w: 0.15
            h: 0.15
Post by G3GJA » Tue Jun 13, 2023 4:16 pm
Philippe
I used WinSC to copy/edit the config.yaml directly from the Raspberry Pi in the GB3EY repeater batc.org.uk/live/gb3ey to give you the code for the OSD section.
If it doesn't work then you need to look elsewhere for the problem as that code is correct. I can send you the complete config.yaml file if that would help you; contact me via contests@batc.tv if you want it.
Clive
MW0RUD
Post by MW0RUD » Sun Jun 18, 2023 11:12 am
Hi Philippe,
I've copied the settings you gave into a stock config file and they appear to work as shown in this screenshot
I've zipped up and attached that confilg file as an example.
Tim
config.F5ZMG.zip
(1.44 KiB) Downloaded 940 times
Philippe
Post by Philippe » Mon Jun 19, 2023 6:45 am
Hello Tim
I just put your file in the RYDE directory and it works hi!!
I don't understand why with my config files it doesn't work
I use WINSCP
can you tell me where is my mistake?
A big thank you I was starting to lose my mind
Best Regards
73 Philippe F5AOD
Philippe
Post by Philippe » Tue Jun 20, 2023 6:10 am
Hello Tim
I did some tests with the config.F5ZMG.yaml file and indeed the indications are there permanently
I wanted to make a modification to add the MER but it does not work I wonder what the mistake I made
Is there any help? I did not find !
Best Regards
73 Philippe
