Portsdown 2018 Stretch Software News
Re: Portsdown 2018 Stretch Software News
Post by G8GKQ » Mon Aug 06, 2018 9:53 am
Hi Mike
As discussed yesterday, we did a number of updates and new card builds on Saturday which all worked perfectly. I think that your cards might have been corrupted by some of the testing that I had asked you to do - not sure if I should say sorry or thanks, both apply!
I suggest that you rebuild both your cards from scratch using the instructions here:https://github.com/BritishAmateurTelevi ... ch-version.
You can back up some of your settings(but not all) on to a USB stick before you do the card rebuild using an option in the advanced setup menu.
PS - Jessie is still being updated, but I would prefer that everyone moves to the Stretch version as soon as possible
m0xtd
Post by m0xtd » Mon Aug 06, 2018 10:55 pm
Update installed without a problem and also added the Lime Mini support.
Can confirm that I have now got the Lime Mini tx-ing and being received on a Minitiouner. Signal keeps dropping out every so often but that just might be my setup on the bench here. Will continue and let you know. Can the Lime Mini be used instead of the RTL-SDR for the spectrum view?
Couple of quick comments for you on the Release 201807290 software. I'm not sure of this was present before as I only noticed it today. I also realised that I used the June update of Stretch by mistake but so far, everything appears to function ok.
1. Change to Pi OTP settings. If you provide a MPG2/VC1 decode string in /boot/config.txt, that change is now stored in some of the one time programming entries and no longer needs to be quoted in the config.txt file.
"vcgencmd otp_dump" shows the OTP parameters and 45/46 are the MPG2/VC1 codec entries.
What this means is that a R-Pi may now be licensed for MPG2/VC1 decode but that there is no entry in the config.txt startup file. Might affect how you report this on the MPEG2 license menu.
2. I think I am right in that the only way to enter my BATC stream details is to directly edit one of the settings files (portsdown-config.txt) and change the streamkey parameter. Whilst there (and this was before I ran any setup from the touchscreen) I edited the call and locator parameters to be my callsign and qth. However, on rebooting the Portsdown and checking the bearings of other users, the software was quoting my correct callsign but wrong locator (quoted IO90.... ). Had to use the update facility on the menus to enter my locator again, after which bearings where being correctly reported. Probably not a problem but might suggest that different functions are reading locator codes from different locations.
3. (This was observed on previous installations) Is there a way to leave the Portsdown on a specific output band on shutdown? Only asking this as mine seems to always want to enable the 2m output on shutdown, irrespective of which band I was experimenting with?
4. Constellation diagram. This is something I have observed - I have no clue if this is to be expected or indicates that I have further tuning to do on my setup. When I use a DTX1 or the LimeMini as a source for a signal, and use MiniTiouner as the decoder/display, the constellation tends to be very concentrated on the four points. The signals are very concentrated and very symmetrical. However, using the Portsdown, the constellation patterns appear differently - with one (the lower right) being in the expected position whilst the other three appear to be shifted slightly down and to the right. I will get some pictures tomorrow and update this but just wondering of there is anything else I need to do on the setup?
I also have the streaming working and getting some nice results. Laptop is taking a bit of a hammering and is starting to show its age (it's a Core 2 Duo T9300 with 4GB) though.....
Really pleased with my build and thanks for all your help.
73s
Ciaran
M0XTD
Post by G8GKQ » Tue Aug 07, 2018 9:15 pm
Hi Ciaran
Lime Mini support is very experimental at present. The BATC Filter-Modulator is currently the better option. Spectrum View is RTL-SDR only.
I use the command
vcgencmd codec_enabled MPG2
to check the OTP settings, so have this covered.
No - you can set this parameter from the Console when you select Stream as an output. It will be available from the touchscreen as soon as I have time to implement the code.
There are 2 locators stored. A 6-figure one for video captions, and a 6 or 8 or 10 figure one for bearing and range calulations. If you use the intended user interface (either touchscreen or console), they are both updated correctly. If you try to hack the config files without doing both, you will not get the right result.
The band selection is determined by the voltage on 2 GPIO lines. When you shut down the RPi, these go to zero volts, so select the 71 MHz band. I can't get electricity out of nowhere!
This could be caused by one of 3 things: LO leakage from the ADF4351 to your receiver, lack of an LO filter, or operation at 71 MHz below the specification of the IQ modulator. The fact that the signals are not generated by an SDR means that the points are not as sharp.
Hope that helps you understand some of the issues!
Post by g0mjw » Fri Aug 10, 2018 10:28 am
Hi Mike
I tried this and it would not work on IQ mode at all. After 5 re-installs I finally figured out that the problem is that the default audio was set to auto rather than off as it apparently needs to be if there is no audio device connected. I am now wondering if this is behind several other past problems.
Post by G8GKQ » Fri Aug 10, 2018 6:34 pm
Mike and I have now found the cause of his problems. He was using the "Save Settings to USB Drive" function on a very old (more than 1 year) Portsdown and then importing the settings to the latest build. There were a number of incompatibilities, but the one causing the most problems was that analogcamname was set to /dev/video0 and should have been set to auto.
I am going to rebuild the "Save settings to USB" functionality soon, but the main thing to note from Mike's experience is that it will only work if the exporting and importing Portsdowns use compatible settings. Unfortunately, these settings do change over time as the Portsdown gains new features.
m0xtd
Post by m0xtd » Mon Aug 20, 2018 10:42 pm
Thanks for the reply and apologies for the delay in responding.
All understood on the risks of "editing" things - I'm quite skilled now in rebuilding SD cards for the Portsdown!
Reference the constellation question, I saw a few other posts referring to this and since I posted the comment, things have changed - I did rework some of the internals of the case and results are better. Hopefully show you at CAT18.
73s
Ciaran
GI4DOH
Post by GI4DOH » Mon Sep 03, 2018 5:06 pm
My Portsdown hung today a few times while I was testing a 70cm amp. I was stepping through ranges of attenuation to check for linearity through my amplification chain. basically i would change the attenuator setting by 1dB, transmit for a few seconds then stop and change the attenuator again. On the occasions that the Portsdown hung I had to do a power off reset.
I ended up with a state where the RPi wouldn't start up - I assume the SD card had been corrupted.
I reformatted the card and did a clean build following the instructions at https://github.com/BritishAmateurTelevi ... ch-version
Everything seemed to go OK with the updates except I just get the Portsdown logo on the screen and a message 'Noty connected'.
When I log on with SSH I get a message '-bash: /home/pi/rpidatv/bin/rpidatvgui : No such file or directory.
The '/home/pi/rpidatv/scripts/menu.sh menu' command takes be to the GUI OK but the 'Restore TouchScreen' command doesn't do anything for me.
I tried a clean build on another microSD card with same result.
Any ideas anyone?
73 Richard GI4DOH
Post by G8GKQ » Mon Sep 03, 2018 9:22 pm
Hi Richard
Sorry to hear of your problems. I will do a test build tomorrow to see if I can reproduce them.
In the meantime, the only thing that I can think of that might cause the problem with your rebuild is intermittent internet connectivity. Suggest you do nothing until I have validated the build again.
Post by G8GKQ » Mon Sep 03, 2018 10:08 pm
Hi Richard
I have just done a test build which has worked as expected.
I am a bit confused with your error message of the "Portsdown logo on the screen and a message 'Noty connected'.". This is not an error message that I would expect from the Portsdown Stretch build - it was only displayed in the old Jessie build.
Please could you try to build the card with Stretch Lite once more and make sure that you use this text for the build:
wget https://raw.githubusercontent.com/BritishAmateurTelevisionClub/portsdown/master/install.sh
chmod +x install.sh
./install.sh
If it does not work, copy all the text from the Putty screen (right click in the title line and then selcect "Copy all to Clipboard")and paste it into notepad and then e-mail it to me as a text file. I will then look for the error.
The finished card should boot to the touchscreen and work in MPEG-2 modes. There is still an issue with the H264 modes.
GI4DOH
Post by GI4DOH » Tue Sep 04, 2018 11:07 am
Hi Dave - many thanks for the reply. That has done the trick and I am up and running again.
The problem seems to have been that I followed the path from https://wiki.batc.org.uk/Portsdown_software leading to https://github.com/BritishAmateurTelevi ... /README.md and that tells you to do the line wget https://raw.githubusercontent.com/Briti ... install.sh.
This is different to what you have just stated - wget https://raw.githubusercontent.com/Briti ... install.sh.
I have made a note of the correct command for future reference but it may be worth adding a note on the instructions to stop others going the same way.
So it's back to business - thanks again.
Richard GI4DOH
