HamTV Reception Reports
IU2KAC
Re: HamTV Reception Reports
Post by IU2KAC » Fri Aug 08, 2025 6:38 am
g4hiz wrote:
Thu Aug 07, 2025 9:00 pm
Hi Liborio,
on a test today with the 90cm dish static pointed for an 83 degree elevation pass, the time for the ISS signal to emerge and then disappear back into the spectrum analyser noise floor was about 24 seconds. There was about 20s above the threshold for demodulation, with the receiver taking about 5s to lock, giving up to about 15s of video, with a peak of D14. There was sufficient viewing angle and strength of signal to see pickup on the first side-lode of the antenna.
The antenna was aligned with very simple tools. Although for any particular location, one should take into account the local variation of Magnetic North versus True North.
Jen G4HIZ
Edited to add 2 photos and a bit more explanation
Hi Jen,
Thank you for your valuable information, which will be very useful to other OMs interested in receiving the ISS.
Congratulations again on the work you've accomplished!
EA6WQ
Post by EA6WQ » Fri Aug 08, 2025 9:44 pm
Another good reception in EA6 Mallorca Island - 8 Aug 2025 17:00 - 17:11 locat time max elev 80º
120 cm dish, Spid Ras /HD 0.1 º rotator , QO-100 Poty feed, DG0VE preamp, 35 mts Sat Coax , Minitonuer Rx, peak MER 12 D11 - Black picture
Most of the time video decoded during the second half the the pass , up to about 20º
73's de
2nd HamTV ISS  RX
2nd HamTV ISS RX
2nd HamTV ISS RX.png (1.8 MiB) Viewed 6825 times
2nd HamTV ISS  RX
2nd HamTV ISS RX
Tom, EA6WQ / KE0KQT
EA6WQ
Post by EA6WQ » Sat Aug 09, 2025 3:33 pm
G4IMO-TV wrote:
Fri Aug 01, 2025 10:14 am
Just for info:- It is possible to receive pictures using a cheap aliexpress MMDS BT-281 2.2 - 2.4Ghz downconverter. Downconverting to 557Mhz into the Minitiouner. Just remove the dipole, fit an N Socket, and connect directly to the feed. Even with a quoted NF of 2.5 dB I managed MER of 7.4 on a 1M dish.
Nick.
Hi Nick, tnx for you report.
I tested one of these last year without success, trying to receive Coriolis Satellite,installed a N connector that fited perfecly and powered it with 12v inline the coaxcable, can you please share
how did you powered your one ???
Tnx,
Tom, EA6WQ/KE0KQT
G4IMO-TV
Post by G4IMO-TV » Sat Aug 09, 2025 3:48 pm
Hi Tom - I just connected it to the MiniTioune F Plug input, so that would be about 17 volts up the coax to the converter. I think you might need more than 12 volts.
Nick
G4IMO
EA6WQ
Post by EA6WQ » Sat Aug 09, 2025 5:15 pm
Nick
G4IMO
Thanks alot Nick, will try with 18v
73s
IU2KAC
Post by IU2KAC » Mon Aug 11, 2025 1:24 pm
I wanted to try two days ago with a 60 cm dish and an old 30 dB LNA with 0.8 NF.
I managed to receive it for 3 seconds with a D2 signal.
Today I wanted to try with an 80 cm dish, but incredibly, I didn't receive anything!!?
Was ISS HAMTV turned off today by any chance?
Thanks for the reply.
73 Liborio IU2KAC
Imagehttps://imgur.com/a/o2bcZY5
Imagehttps://imgur.com/a/0DzSvlw
EA6WQ
Post by EA6WQ » Mon Aug 11, 2025 8:26 pm
73 Liborio IU2KAC
Hello Liborio, i did not try today so i dont know.
I will try again in a few days.
tom, EA6WQ/KE0KQT
g4hiz
Post by g4hiz » Tue Aug 12, 2025 6:01 am
Hi all,
personally, I have not tried to receive the ISS since Saturday.
One thing I do before attempting reception is to transmit a low power local calibration signal to check out my equipment, ie is it working in general, is it on frequency etc. ? I use a CW carrier of -40dBm into a small antenna and observe this on the Portsdown Bandviewer or my Spectrum Analyser, with the source being about 10m from my antenna. An ADF4351 programmed to 2395MHz would do the job, suitably attenuated.
It would be useful if there was a HamTV status page available somewhere showing for example, Tx status On/Off, Video status Black/Camera, in order to inform folks who may be testing their receive setup.
Jen G4HIZ
IU2KAC
Post by IU2KAC » Tue Aug 12, 2025 6:40 am
Hi all,
Jen G4HIZ
I completely agree with what you said.
It would actually be helpful if there was a HamTV status page (ON/OFF) somewhere.
IU2KAC
Post by IU2KAC » Tue Aug 12, 2025 6:42 am
73 Liborio IU2KAC
tom, EA6WQ/KE0KQT
Ok Tom let us know.
Return to “ARISS HamTV”
