Secure Reliable Transport
G4FKK
Re: Secure Reliable Transport
Post by G4FKK » Mon May 26, 2025 10:59 am
Assuming the switcher that Martin lent me while I was cobbling together the logic board is identical to the one he's using currently, then that is described as seamless in the spec'. I suspect VLC or the ZOE encoder box is possibly objecting to a change of format when the switcher changes from 4 screen mode to a single screen mode and vice versa. The worryingly named software John, JTT, has unearthed also objects but then tries reconnecting until it's happy again (excuse the pun).
EA7KIR
Post by EA7KIR » Mon May 26, 2025 11:40 am
I agree Martin. I think the only true way is to standards convert and synchronise the incoming before switching. This more or less is what the ATEM Mini and similar devices do..
Michael EA7KIR
G8KOE
Post by G8KOE » Tue May 27, 2025 8:58 am
NEW LOOK FOR MY SRT REPEATER
73's
Martin
G8KOE
G8KOE
Post by G8KOE » Thu Jun 05, 2025 7:56 pm
Haivision Play ISR Video Player
https://www.haivision.com/products/download-play-isr/
This works well for receiving my SRT REPEATER and it's FREE
73's
Martin
G8KOE
vk3ttf
Post by vk3ttf » Fri Jun 06, 2025 12:47 am
Awesome, you worked out the bars picture change, looks much better now with the custom screens. Great work.
vk3ttf
Post by vk3ttf » Fri Jun 06, 2025 12:49 am
Haivision Pro is also good for sending SRT streams. All you need is an old/phone tablet, and configure the app to send the stream from the phone camera, so a super simple portable setup. Scroll down on my Blog page here for the app setup instructions.
https://blog.hardtechnology.net/post/srt-streaming/
G8KOE
Post by G8KOE » Sun Jun 08, 2025 5:57 am
Also works well with a BATC Stream
73's
Martin
G8KOE
Post by G8KOE » Thu Jun 12, 2025 6:39 am
INTERMITTENT CONNECTION
I have been experiencing problems with intermittent connection to my SRT Repeater.
This I thought was a network problem but have found that the updated firmware to my ZowieBox encoder is unstable.
Now running the previous firmware 1.1.0.1
This will not overcome a poor network signal but helps with a more stable system.
I have also found that the RYDE is an excellent way to watch the g8koe BATC Stream. (This is my SRT Repeater )
73,s
Martin
G8KOE
G8KOE
Post by G8KOE » Thu Jun 12, 2025 2:13 pm
ALL DID NOT GO WELL
Downgraded the firmware all looked good except had no sound.
Chasing lots of problems.
So far playing all day with settings etc.
Repeater not function as it should!
73’s
Martin
G8KOE
G8KOE
Post by G8KOE » Fri Jun 13, 2025 9:47 am
ZowieTek Encoder has stopped working reliably.
The encoder has stopped reliably detecting a valid HDMI input.
NEW SETUP FOR SRT REPEATER
I have removed the ZowieTek box and replaced it with a PC running OBS.
There will no longer be a stream to BATC!
So far the PC is looking promising.
Tests today done with Martin G4FKK.
Switching between modes seem smoother.
You may find VLC will now work with the quicker transitions.
All input and output settings for SRT REPEATER haven’t changed.
More tests to do fingers crossed!
73’s
Martin
G8KOE
