Pico tuner help
Re: Pico tuner help
Hi all,
now working, Dave, Brian, Keith, Gareth and Mike.....thanks for all your help...
Reinstalled the software with a different SD card
Dave, the lightning bolt only started showing since I connected the Picotuner..will investigate...
Regards
Regards
- PXL_20240818_224411507.jpg (181.3 KiB) Viewed 8325 times
Re: Pico tuner help
HI Dave,
Glad it's all working for you, perhaps see you on qo-100 sometime.
Re: Pico tuner help
The Picotuner (actually the NIM in the Picotuner) does take quite a lot of current if powered from USB. Technically it is more than is recommended for a USB device and may be pulling down the power supply you are using for the Portsdown.
If this proves to be a problem then the Picotuner can always be powered externally from 12V.
Colin G4EML
Colin G4EML
Re: Pico tuner help
Hi Colin,
thanks for the info....it did the trick..no lightning bolt!!!!
Brian, thanks for all your help....at the rate I build QO100 is a long way off....
Re: Pico tuner help
deleted due to my error
Steve G3GHZ
Canewdon Essex JO01IO
5665 ATV FM
5665 ATV FM
Re: Pico tuner help
D8 is just a diode and D6 is a TVS diode on the PCB, in the Schematic and in the BOM - are you reading the right files for V3?
Re: Pico tuner help
Deleted due to my error of reading circuit
Steve G3GHZ
5665 ATV FM
5665 ATV FM
