IARU Region 1 ATV Contest 11/12 June 2022
it9gnj
Re: IARU Region 1 ATV Contest 11/12 June 2022
Post by it9gnj » Thu Jun 30, 2022 8:42 pm
Hi everyone, the IO9DATV team (IW9ARO, IT9FUR, IW9GUR, IT9GAJ, IT9GNJ, IT9SWH) had a big surprise when we got the the Renny PE1ASH signal on 6m.
We built our 6m / 70cm upconverter but we haven't received any important signals yet, just workbench tests. On the last day before the contest we built a BPF for 6m + LNA with PGA103+, connected in front of our upconverter. Surely the qso could be done even without adding this device.
Renny PE1ASH transmitted at 51.700MHz, 125ks, 2/5 FEC, we received with our Diamond HB9CV antenna at 4m from the ground, MER 12.3dB with D13 !!!
Post by M0DTS » Fri Jul 01, 2022 9:47 am
Excellent work, This is a big achievement for Es DATV!
I'm interested to try DATV on 6m so if any of the team are available for tests please let me know.
You guys are at a good Es distance from IO94.
I can Tx ~100w DVB-S2 to 5element yagi on 51.7.
PA3CRX
Post by PA3CRX » Mon Jul 11, 2022 12:06 pm
Renny informed me that he did not even had the intention to use Es.
Hij pointed his home made 4 elements quad (30 mtr above street level) to a station at about 10 km's distance and switched the transmitter on.
Some later an email arrived from the IO9DATV team.
Now he is eager to make more Es contacts of course :D
KenW6HHC
Changes added to Known DATV DX Records list
Post by KenW6HHC » Fri Jul 29, 2022 11:23 pm
The PDF records sheet on the BATC wiki has been updated with four new DX records of note.
See https://wiki.batc.org.uk/UK_ATV_DX_Records
50 MHz DVB-S2 QSO of PE1ASH and IO9DATV (team) on 2022-06-11 1760 KM
440 MHz DVB-S2 QSO of IZ5TEP / IT9HZM and IT9GA / IW9GUR / IW9ARO on 2022-05-15 903 KM
2.4 GHz DVB-S2 QSO of IZ5TEP / IT9HZM and IT9GA / IW9GUR / IW9ARO on 2022-05-15 903 KM
10 GHz DVB-S2 QSO of IZ5TEP / IT9HZM and IT9GA / IW9GUR / IW9ARO on 2022-05-15 903 KM
Please send me an e-mail if you know of a DATV QSO that should be added to this list (via W6HHC@ARRL.net)
73…de Ken W6HHC
