Activity weekend 2/3rd October 2021
G4NZV
Re: Activity weekend 2/3rd October 2021
Post by G4NZV » Sat Oct 09, 2021 6:31 pm
Reception of M0DTS over a 281Km Path on 436.5MHz DVBS2 125KS FEC 1/2
Thanks for taking the time. Shame about DVBT
73 Steve G4NZV
M0DTS DVBS2 20211009-4.jpg (570.4 KiB) Viewed 5364 times
M0DTS DVBS2 20211009-3.jpg (425.93 KiB) Viewed 5364 times
Post by radiogareth » Sun Oct 10, 2021 8:06 am
Well my mast is up but I'm struggling to get into GB3HV this morning - usually 20+ MER. Must be 'atmospheric absorption' (mist)??? Able to listen on DVBS & DVBT, also TX on both if anyone wants to try. Will be on Zellow ATVSouth.
JO01AI09KQ Hayes Bromley Kent (SE London).
Post by radiogareth » Sun Oct 10, 2021 6:45 pm
Poor access to HV was down to a N-Type plug sliding off the end of the mast coax feed....with that fixed Martin was found on HV and persuaded to swing the beam around. Not a lot seen with direct beam headings but I suggested we tried bouncing off the Crystal Palace towers which we can both see. About 2-3dB was then discernible over the noise floor (good old Band Viewer :-)) but Martin thinks the signal was most likely diffracting around the edge of the Shirley Hills which are between us. By dropping to 250ks we just scraped a 2-way, with 12dBd beams each end and 50 watts!!
Given that the same path can be done with 1/2 a watt at 2m and 4m, an interesting experiment....
