Portsdown 4 - First build now available
Re: Portsdown 4 - First build now available
Hi Roland,
as Dave wrote above, the integration of Pluto is experimental at the moment.
not all features work.
73 Thomas DL5BCA
73 Thomas DL5BCA
I always have crazy ideas.
Please don't be surprised.
Saro
What USB device are you talking about?
and LimeSDR or Pluto?
I am using Pluto and Lime USB Both working fine with TestCard Tx, I want use the video from USB pen drive.... In the Video Source i am unable to find my USB drive...How to add the video source from USB Pen drive?
Saro
Saro
Hi Saro
That feature is not included in the Portsdown Software. You could modify the file rpidatv/scripts/a.sh to do it, but there would be no touchscreen support for the feature.
After the next update (202008050, due today or tomorrow), the composite video input (using an EasyCap video capture device) will be enabled for the Pluto. You could then use an external media player.
Quick question I have a Pie 4 2GB coming tomorrow, will it work with the Custom Firmware for Lime Mini, Lime DVB Output or do I need to go back to the latest Lime Mini Firmware so I can just swap the Lime Mini over.
Simon
Simon
Hi Simon
It should work with the Custom DVB firmware, just the same as the old version. I think I have tested it....
Yep works a treat was using custom firmware yesterday evening whilst out portable and was good from 4Ms to 333Ks.
73 John G7JTT
73 John G7JTT
Hi Dave & John,
Brilliant, thanks for the confirmation, happy days
Simon G4OUK
Simon G4OUK
Have a question regarding the performance improvement of the Pi 4 over the Pi 3B when using H264 Modes. I know the Pi 4 has a much more powerful CPU, faster memory, 4K HDMI output, etc. My Pi 3 struggles when using H264 on anything above 4:3 using the built in Test Card using 1 or 2 M/S or even 4 M/S. Have you had a chance to test the performance improvement using H264 particularly when using 720p and 1080p and at what Symbol Rate?
Simon G4OUK
Simon G4OUK
I am getting a strange error today checking for updates on 202008011 (menu 33) on the Langstone.
"Unable to connect to github for update, Internet connection to google sees OK, please check BATC Wiki FAQ for advice."
Now this would be fine except there is no FAQ section on the Wiki. I know why and what to do but thought I would mention this.
